Hello Everyone.
Thanks for the wishes Johannes, but my wife had some plans, but for quite a few hours I was in the hobby room! What a woman I have!
Anyway. between the Mirage IIIR for Paparazzi Campaign, the F6F-5N Hellcat for the other build log and a Kitech (argh!!) FB-111A for the Swing -Wing campaign, I finally finished off the Lightning!
No REAL problems at the end, except for a few frustrating parts where things didn't go right. The main problem was, as you may know, the paint. After finally undercoating the gun bay panels the paint sticks to them fine. BUT I wasn't going to strip and paint the rest of the plane so I worked around the paint problem.
I also had a heart stopper when the final matt coat came out like the plane had frost all over it. I swore a bit then sprayed it again with paint from a fresh jar and it seemed to work well, and it fixed the frosty look as well.. luckily..
Then I discovered I had forgotten to mask the engine inspection windows in the inner sides of the booms before applying the matt coat. A cotton bud and some metho solved that problem.
The final part to put on was the canopy in the open position. Couldn't just use CA and spray on the accelerator as it isn't good for windows as I found out earlier. So I had an idea to spray the accelerator into a small plastic lid and apply it with a small wooden skewer. Worked fine after the first time when the skewer stuck to the canopy as well!
Please excuse the small tail prop. It won't be needed much longer as I have an idea for a small diorama involving tie down chains and a field. I have the chain already and will have the field tomorrow so I will post a piccy or two when I get to do the diorama.
Sorry for the size of the photos but I am running out of space!!
The wee beasty!
I tried to give the aluminium a weathered, dull look that was a bit patchy, and I think I succeeded.
The 'Office'. Sorry you can't see much but the canopy is pretty heavily framed.
As you can see I didn't do Itsy Bitsy II due to the paint problems. Maybe next time. I like the kit and there will be a next time.
Centre nacelle and the port engine.
The business end of the beasty. You can't see it in the piccies but I did the aerials from stretched sprue.
I HAD to ise the rocket trees as they were a P-38L signature item. This is a scheme of a light grey body with olive drab noses as I found on a website showing a Hellcat with these same rockets. Just call it artistic license if it is wrong.
If anyone would like some more piccies just send me a request and I will send them to you via email.
Thanks again to all who have had a look.
