I have just started building again, after a 10 year break. I am part way through building a series of kits to represent some of the aircraft used by the PDU in late February 1940. I am building Spitfire N3069 (a PR Mk.Ib at this time), using the Tamiya Mk.Ia kit as a basis, with Aires cockpit, and a vac-formed canopy with teardrops. I have made some major mistakes already- the wheel wells are the wrong colour, the cockpit detail is probably wrong (there is too much stuff on the walls of the aires cockpit for a MkI I think), when installing the cockpit, I glued the sides of the fuselage together under tension. Only afterwards did I realise how deformed the wing roots had become. I had to butcher them badly to get the wings to go on
The most major error was that I used an old diagram of the camera mounts in the wings, and it showed a small teardrop blister around the lenses. After I made these and added them, I saw clear photos of a PR Ib with the glass windows for the lenses flush with the underside of the wing...
This was my first attempt at using an airbrush. I am using Xtracryllix paints. I undercoated the plane in white, and pre-shaded with black, then sprayed over in camotint (Sky lightened quite a bit with white).
Anyway, the other planes I will be making are:
Hudson N7334 (shot down by friendly fire on 3rd March), which has a interesting camouflage scheme:
I'll be using the MPM Hudson MkI kit. The interior on this kit looks really nice. It can also be made into different aircraft (e.g. Lockheed 14, later Hudsons). There is a model of an aircraft in this camo sheme here: http://passionmaquettes47.free.fr/MAQUETTE...DSON/index.html
I've started on Cotton's famous Lockheed 12A, G-AFTL, using Special Hobby's version, which seems quite nice, but is a little harder to assemble than a mainstream kit (vac-form canopy, no alignment pegs). Here is a great looking build of this model:
http://sturm.szm.sk/kod/stranky/l12_m.html
Then finally, I am building a Beechcraft Staggerwing 17, using the Sword D-17S model (see this review: http://modelingmadness.com/reviews/allies/us/hammstagg.htm ). The plane I am making is G-AESJ, a C-17R, which has a shorter fuselage, steeper windscreen, different engine and different tail to the model. But it is too much work to correct these problems, unfortunately! This aircraft carried an SIS/MI6 photographer (who usually took passport photos for forging papers for agents) to photograph the German navy at Wilhelmshaven on Septemember 2nd 1939, on the eve of the declaration of war. It was also used as a general communications aircraft by the Unit.
Here are some shots of my model's interior (I now know the wheel is on upside-down!)
I am having a nightmare with choosing a suitable glue for clear parts (as seen above). I have just bought some Krystal Klear, so hopefully this will solve my problems.
Thanks for reading this far!
