It's been some time since I posted anything about my progress. So let me fix this now.
First few words about the Airfix kit and the Aeroclub aftermarket. Let's take a look on the spinners shape. Is Aeroclub much better?
Now let's go to the propellers blades. The difference is much more visible here. Aeroclub blades are casted together with the rear part of the spinner (looks awfull).
and a closer look
Well, the Aeroclub would be a good choose in the first moment, but let's try to put the tiles together.
As you see it doesn't look so perfect. Aeroclub has better shape, Airfix has much better fit. What to do? I decided to take the rear part of the spinner from the Airfix kit and the spinner from the Aeroclub. Then I'll chop off the blades from the Aeroclub "casting" and try to fix them somehow to the spinner. How to do that - I have no idea...yet.
And as a prove I did something with the model here are other pics.
Due to the reshaping of the wing I had to completely rework the flaps by filling the gaps with putty and sanding. There's still a second flap waiting to do.
And a bit of progress with the rear. Reshaped and backdated stabalizers from the Aeroclub.
and the in-progress pic of the second one.
Let's go back to the wings and airlerons. It was a very time consuming work here. Although the airleron itself doesn't look so bad
I'm affraid I thined it too much and it's visible when joined with the wing.
so it will have to be fixed in the following position which makes all the gaps less visible.
and the last picture showing how the airleron will the joined with the wing
All always: all critiqe and good advices are welcome.
