For now, i made a little further progress on the '109'
the horizontal stabilizers together with the elevators are glued onto the fuselage, together with the stabilizer struts.
The wing half's are now glued together, and some reinforcements styreen is glued into the space between the upper and lower wing half's.
This was done because the wing didn't quit match with the wing-root on the fuselage.
The upper wing half was lifted some 1/2 m/m when the styreen reinforcement was installed.
After that i tackled the engine cowl.
For this i used some Eduard PE part's, to give the cowl a more realistic appearance.
For me, the difficult part was the supercharger air intake, because the kit part was no more then a plastic part, with no realistic grills, that where closed also, so, i needed the help of Mr. Eduard.
Eduard gave me a nice little PE sheet, that had to be folded together with the help of my Etch-Mate.
After the air intake was folded, it was time to use my soldering iron, wich was very helpfull to give a solid bound to the tiny PE part.
This is the PE part, compared to the kit part.
Also, the Master metal MG17 barrels where fitted to the cowl.
The quickboost exhaust are glued with 5-minutes epoxy glue.
Because the '109' has a rectangular opening, aft of the propeller spinner, with no grilling, the interior of this compartiment show's allot of piping.
To get this effect also, i added some copper and styreen rods, to give a somewhat interior look.
Inside the engine compartiment, the wirering is glued with 5-minute epoxy glue.
Outside, it looks like this
That's all for now.
Greetz
Danny
