The first stages have been strange- working backwards from a completed model. Initially I was just going to re-paint it, but I have to correct a few things first... It is the car-door Revell release, with a home-made metal 4 blade prop and vac canopy. I stripped the paint with Mr. Muscle oven cleaner, then removed the wings for access to the cockpit. I shall be upgrading it with MDC bits (thanks to Bob for supplying a strange assortment of parts!).
MDC goodies- tailplanes, seat and headrest, 4 blade prop, radiator, radiator filter, gunsight and its framework
The model's napalm tanks were mounted on racks in the earlier location- the later bomb rack location was more outboard- almost mid-way between the cannons- which was a stronger part of the wing, and enabled the carriage of 1000 lb bombs. The inboard position could still be used for long-range 44 gal fuel tanks with the outboard bomb racks still in place (without anything attached though).
Drilled out the exhausts.
Radiator flap has been cut out.
Front edges of the cockpit have been re-cut at a different angle- the front part of the bubble canopy was deeper than the steep windscreen of the car-door canopy.
This will be my first attempt at re-scribing an entire model! The markings will be painted with Miracle Masks, a couple of home-printed transfers for small details. I might have a go at printing stencil transfers too. This is hopefully going to be a bit of a speed build, as I want to get it back to its owner ASAP.
