Sean,
Thanks for the kind words. If you can't find the 'Invisi Thread let me know.
The scollop demarcation line was a length of masking tape, then I applied some Humbrol Maskol, using a 'Q' tip to get the arched line as neat as possible. When touch dry the Maskol and tape was removed and using the tape, as a means of removing any excess Maskol and / or any peeling paint. Simply by pressing on the surface with the tape and lifting off the flaked paintwork.
As I guessed the width of the AEAF Bands, for both the wings and fuselage, I used 2 of the white backing discs {from a Tamiya 48 Spitfire kit}, as a base for the main wing roundels, over the AEAF Bands, some of the original kit decals {such as the wing walk outlines} and some other decals from the 'spares box' along with a fictional mission tally and nose art to finish this bird.
The trailing antenia is 2 pices of 'Invisi Thread', the pitot tube on the top of the rudder post is a scratch built addition, {the kit instructions show this part, but do not supply it in the kit} and drilled out the holes from the canopy roof prior to gluing it in place, with the aide of 2 small pieces of brass wire.
The panel lines are highlighted using a 50/50 mix of Tamiya Smoke and Flatt Black, mixed as a 15 {thinner} - 1{paint} ratio and airbrushed free hand over the model, in several applications, other weathering effects are a mix of Pastels and the Tamiya 'Weathering Sets'
So i can now call this as finished.
Note: The wing tip nav lights are clear parts taken from the 'left over' P-39 Airacobra kit, I painted the locating pin stems in either a clear red or blue and drilled a hole into the centre of the marked area of the kit detail, slightly bigger than the lense locating pin of the clear part.
For a little extra realism.
