First, I installed the top shoulder belt buckles (or so I thought anyway) using the little retainers I made in the last post . . .
However, if you look closely, you'll see that I installed the wrong buckles.
Fortunately, I was able to pop the bottom of the belt retainers loose to change out the parts.
I really like the look of the Eduard prepainted belts (if not the "microsurgery" required to assemble them . . .
I added some "chipping" to the seat (and cockpit floor) before installation, then installed the belts (this time with the correct buckles at the top) . . .
Sometimes when you're bending these Eduard precolored belts into place, the printed coating will tend to chip, but this set thankfully went on with very little touchup required . . .
The belts will need to be "dirtied up" a bit, and they and the chipping will need to be toned down just a tad with filters. I think that after that, they'll look pretty good.
Regards;
Automaton
