Main wings are now rigged , had to go with a different method . The tool I use for making my wire hoops has been missed placed . Don't worry though I have sent out the search party .
I opt for going though the wing . Small holes I drilled only half way on the top underside . Gluing in the webbing of rigging line ( smoked invisible thread ) . Two turn buckle selves were added to each line . Two small holes where then drill next to the struts . The top wing was mounted and the lines pass through the lower wing , pulled tight and fixed with super . When dry this was trimmed flush with the surface and holes file with tamiya putty wipe away with acetone .
This work out rather well for only needing to fill holes on the lower wing . A few paint touch ups and some weathering will finsh this stage off . Next comes the rudder .
