Spent a little time on the Yak, and applied the dot-filter method with oil paints to the uppersurface. As a prep, I sprayed Future/Kleer over the entire model after the decals were set and dry. I gave it a light sanding with a polishing pad to smooth the surface as well as give the oil paint something to hold to.
Here are a couple of "before and after photos" - note the change can be hard to capture with photos as it is very subtle:
Before:
After:
Before:
After:
While I am by no means an expert on this technique (I am still learning), as requested by Damian, I will attempt to share the process in case anyone is interested
First up, here are the supplies I used:
I used the small point brush to apply the oil paint. I used the middle flat brushes to blend the dots, and the large flat brush to blend out anything left over (as the smaller flat brushes can get loaded up with paint towards the end).
First, I apply small dots of each of the colors (yellow orche, green, blue and red in this case) to the surface:
Then I start blending them with the dry, flat, brush using a circular motion:
Then I blend a little more until they just about "disappear":
Then a little final work with the large flat brush and we'll call it finished:
The hard part of this technique is stopping at the right time. It is VERY easy to go to the point where you really have nothing left. To complicate things, that point is different for every color (more blending for lighter, less for darker).
I'll let this dry over the weekend, and then do the underside next week. After that, a burnt umber wash will be applied to the panel lines, and then the whole thing will get a coat of flat clear (probably Dullcoat). Then a little more work with some very thin (90%) red brown and black mix (and more flat clear) and it should be wrapped up.
Thanks for looking, comments/questions welcome!
Doug
