Long overdue, finally I feel I have the time to do an update on my build. Work has been pretty thick on the ground for the past month and a half, but I've still had some time for building the odd moment, so some progress has been made. Here's the story so far...
My last installment left me with some gaps to fill on the nacelle. This proved fairly easy work. The back panel behind the pilot got a plastic shim and some glue to stop it from moving, thus cracking the filler. Then some careful sanding and touching up with paint solved the problem nicely. The nose got several layers of filler, until I was satisfied – and the very visible seam on the back had a small strip of masking tape glued in place, to simulate a rib. Before I put it in place, I painted it up a bit, using coloured pencils. This was also a pretty easy fix.
After this it was time to give the whole kit a base coat before painting could begin. I did this in my usual mode, using Tamiya rattle cans in appropriate colours. After this pre-shading and topcoating was done, with a finish of a layer of future. The matt black surface proved very fragile, so rather than waiting until the whole kit was painted before spraying future – I did this in stages.
Last night I mated the lower wings to the body – using a jig to hold the wings in the right position... So here are some pics of the progress:
Nose with a bit of putty – I usually use what here in sweden is called "spackel". This comes in a variety of grades and uses. This type is very fine and is used as a wood filler. It is water based, non toxic, sticks well and sands very easily.
The back gets the filler treatment, with some plastic to shore things up.
Inside of nose, with the tape bit to cover the gap.
Bits getting a base coat. for this one I used Tamiya "german grey". I feel I get the best results if I use a lighter shade than the top coat, letting me modulate the end result with a darker pre shade and a thin top coat.
Masking the alu-non slip strips on the lower wings.
Loads of bits cramming my desk. There is a lot of wing surfaces to this kit. The PC 10 top wing got a chocolat brown pre shading over a lighter green, letting various shades to filter through in the end result... Not sure if its convincing or not?
The Nacelle in a "finished" state. Obviously there are many details still to put in place here.
I have a bit of touch up to do by the telescopic gun mount.
And the other side of things. The "black" is a bit darker in real life – the flash makes it a bit grayer than it actually is. But I very rarely use a full on black – and this top coat is mostly "Nato Black", with a bit of brown in it.
Well folks, that is about it I guess – A bit closer to the end of the project, with some construction about to begin, and of course – Rigging!
Thank You for looking, any and all comments and advice are as usual most welcome!
Best Regards
