Hi Jesper ,
Have a peek in my profile , did a build review with Mark on the dual combo kit .
Over all , it's a great kit ! When attaching the lower wing to the fuselage really make sure you have a excellent fit . This will save some time on the amount of putty and sanding in the wing root . What works really well is fill the seem with putty ( I use Squadron green ) then use a q-tip dipped in lacquer thinner and run this over the putty removing the excess . If you are light on the putty the less sanding will be need . Once the putty has dried prime the area , it will show on where your touch up are needed . One the ones I have built the tailplane is either a perfect fit or it needs a bit of sanding so test fit this area as well .
The cab struts and inter struts need their location holes re-drilled at a angle on the fuselage or you could bend the attachments points on the struts them self very carefully to the angle needed . Other then that no other issue's with how she goes together .
Also check out Stephen's build review and reviews on the Eduard kit , very informative . There are many builds in the archives which will be a aid as well .
If you are going with the wire hoops you might want to try out Bob's Buckles . You can order them with selves of brass tubing as well if you aren't comfortable with the q-tip .
Terri
