Another update on the Fury
Moulding defect a plenty to make good in this kit
Going to install Biggles, painted to represent the white flying suit often affected by RAF fighter pilots in the early 30s Minimal frame detail added inside the cockpit
Fuselage assembly, fits look OK, wing dry fitted to help hold the fus together
Engine bay detail and kit construction precludes detailing the engine. Should have a visible tubular engine mount but the engine bay mouldings take up the space where it should go
Cabane,upper fuselage and undercarriage front legs assembled, fuselage drilled for lift wires and wire installed. The forward set are laid into the undercarriage groove, temporarily secured with cyano then the u/c fitted. Lift wires are doubled. RAF machines had streamline wires and no turnbuckles, I can't model the attachment brackets, drilling components and securing in the holes is neat at least
With and without cowling
Not too much filling. Most detail is too pronounced, this has already been reduced. Planning the all silver scheme with NMF forward fuselage.
Kit so far lacks detail but fits are good and cabane arrangement should make fitting the upper wing easy
