Florida, United States
KitMaker: 2,798 posts
AeroScale: 2,443 posts
Posted: Friday, October 25, 2013 - 02:00 AM UTC
"From time to time, the tree of liberty must be watered with the blood of
tyrants and patriots."
- Thomas Jefferson
IPMS#47611
Posted: Friday, October 25, 2013 - 03:09 AM UTC
Justin,
That is until you get into the build and see this and that, that needs your attention. Before you know it, it's a super detailed one of a kind, masterpiece. 6 months for sure, and with the P-61, it's going to be harder and harder to stay focused. Believe, I know.
On my Workbench:
Just Completed:
Posted: Friday, October 25, 2013 - 04:19 AM UTC
Ahhhh joel idol hands do the devils work
- Thomas Jefferson
IPMS#47611
Posted: Saturday, October 26, 2013 - 01:54 AM UTC
Justin, Ain't that the truth
On my Workbench:
Just Completed:
British Columbia, Canada
Posted: Saturday, October 26, 2013 - 04:34 AM UTC
So the trick is to make your idols without hands. Then they'll just get frustrated.
-Leonardo Da Vinci
Posted: Saturday, October 26, 2013 - 05:57 AM UTC
- Thomas Jefferson
IPMS#47611
Posted: Saturday, October 26, 2013 - 11:25 AM UTC
Well unfortunatly while checking the fit on the intakes I discovered a real bugger of a problem. I thought I had sanded the aires cockpit down enough (paper thin) to fit in between the fusalage halfs.well apparently still not enough.there is a buldge on the right side that will not allow the install of that intake.the only way to fix it is to rip out the aires pit and replace it with the monogram one. But since I have already cut the pit to shreads for the aires set this will take some time or I just buy another 15 dollar kit
so this build is on ice
- Thomas Jefferson
IPMS#47611
Posted: Saturday, October 26, 2013 - 11:33 AM UTC
What about sanding the inside wall of the intake to conform to the bulge? That way you'd at least get this one finished...
-Leonardo Da Vinci
Posted: Saturday, October 26, 2013 - 11:44 AM UTC
Yeah the part that's buldged sits at the top of the intake so I can't with it being way noticible.its not worth the time I will just get another kit and use the supplied pit.
- Thomas Jefferson
IPMS#47611
Posted: Saturday, October 26, 2013 - 01:44 PM UTC
Perhaps yank out the side consoles and instrument panel to be replaced with the resin parts you're going to be yanking out of this soon-to-be paint test hulk?
-Leonardo Da Vinci
Posted: Saturday, October 26, 2013 - 01:50 PM UTC
I'm going to hit it with a hammer and see if that works
I might have figured it out
- Thomas Jefferson
IPMS#47611
Posted: Saturday, October 26, 2013 - 07:12 PM UTC
-Leonardo Da Vinci
Posted: Sunday, October 27, 2013 - 12:47 AM UTC
Jess, Yep. It's just safer that way for us mortals.
On my Workbench:
Just Completed:
Posted: Sunday, October 27, 2013 - 12:53 AM UTC
Justin,
My brother often ran into that exact issue with Resin cockpits just not fitting no matter how much filing and sanding he did. He got one for his 1/32 scale F-80 literally paper thin, and it still didn't allow the fuselage halves to close properly.
I've often wondered how they can release these AM cockpits/parts (not all, just the impossible fitting ones), without test fitting them. Can't be that they fit their test kits but no one else's.
I'm a little lost. Is the F-102A on hold, on hold till you find another kit down the road, or is it still an active build while you look for another Monogram kit ?
Like I said, I was looking forward to watching your mastery of re-scribing on this build.
On my Workbench:
Just Completed:
Posted: Sunday, October 27, 2013 - 02:42 AM UTC
Its in the think tank
Jess I love the cartoon it use to be my favorite back when I read the news paper.before the internet
- Thomas Jefferson
IPMS#47611
Posted: Sunday, October 27, 2013 - 03:04 AM UTC
Justin, the perfect answer: The Think Tank. You should be in politics.
On my Workbench:
Just Completed:
Posted: Sunday, October 27, 2013 - 03:13 AM UTC
I'm going to take a closer look today and try to het a fresh look at it.I will post pics in a bit
- Thomas Jefferson
IPMS#47611
Posted: Sunday, October 27, 2013 - 05:28 AM UTC
Resin is strange stuff. It shrinks or expands unpredictably while curing so you never know exactly how the finished product will turn out. Even when the masters fit exactly, parts cast from them may not. It's all part of the joys of working with aftermarket.
-Leonardo Da Vinci
Posted: Sunday, October 27, 2013 - 10:07 AM UTC
Jessica, I've watched and followed many 1/32 scale builds of my brother, as he had to work his magic to get those resin cockpits to fit. Most did with a lot of effort. My only adventure with resin, was the engine in the SBD-4, and it was a perfect fit without having to do a thing. Guess I was really very lucky.
On my Workbench:
Just Completed:
Posted: Sunday, October 27, 2013 - 11:42 AM UTC
Unfortunatly jess is correct altough this is probably the worst one I've come by
- Thomas Jefferson
IPMS#47611
Posted: Monday, October 28, 2013 - 04:02 AM UTC
Justin & Jess, I rarely use AM parts: either resin or PE, as I try to fabricate the extra details from some form of sheet, rod, strip plastic, or other types of material such as copper wire, solder, etc. Even searching through one's spare parts box, or Rube Goldbering the part is detailing.
I've often had a heated exchange with my brother as to whether buying AM parts is detailing or not. My view is no, his view is yes. My contention is that more and more kits these days come with PE, and we're seeing resin starting to show up as well. So if it comes with the kit, it's not extra detailing, but if you purchase the same or similar as AM it's detailing? Makes little sense to me.
On my Workbench:
Just Completed:
Posted: Monday, October 28, 2013 - 05:21 AM UTC
Joel when ever I do open cockpit's I usually go resin. this was going to be that way but has since changed.
Ok so on to my boggle. first pic is showing how I removed the filets on the intakes which since then have been smoothed out and are ready to go on.
this is a pic of the problem that I am dealing with. The buldge is on the right side it was worse but I sanded down the fuselage behind the intake which pulled it closer but I still have about 2 MM of space in order to get it flat. I squeezed the fuselage together and added a support behind the control panel to try and keep it there. I used testors for the slow dry time trying to get a good bond. About 2 hours for that.#2 shows what happens when I release the clamp
I will figure it out its just going to take time.
- Thomas Jefferson
IPMS#47611
Posted: Monday, October 28, 2013 - 05:22 AM UTC
my bad first pic is upside down
- Thomas Jefferson
IPMS#47611
Posted: Tuesday, October 29, 2013 - 12:45 PM UTC
Just wanted to say I'm winning the war
- Thomas Jefferson
IPMS#47611
Posted: Tuesday, October 29, 2013 - 02:36 PM UTC
Justin, WTG!!
On my Workbench:
Just Completed:
