Good Day Gents,
I was able to take some more pics of the build to date.
After applying the decals and doing the panel lines I sprayed some flat coats over the aircraft and added the cockpit seat.
At this point I was looking at the propeller which I had painted in Tamiya Flat Black lightened a bit with Flat white and while it looked fairly accurate I wasn't impressed with the look. It just had an appearance
of a four black sticks with no hues or tones to it. So I decided to re paint it. This time I created a mixture of Flat black, white and a new colour in the form of blue. I mixed all of them together till I got the colour I wanted
then sprayed the prop again. If you look at my previous posts you can see the difference in the colours. The new mix I think has a bit more colour variation in the black which I like. I don't recall the exact ratios I used as I just mixed
the colours till I got the colour I wanted.
A few comments about the bombs. I have seen a number of Typhoon models with rockets and in some cases the modeler has gone to great lengths to add detail to them. i.e. adding the electrical firing cables for the rockets. However, for ones that have had bombs instead I have only seen just the kit bombs painted black and put on the aircraft. As 439 Squadron only used bombs I wanted to provide a greater level of detail for the bombs and create some visual interest. Thus I sourced some British 500 pound bombs from the Eduard Brassin line complete with nose and tail fuzes and detailed bomb markings. These were originally for a spitfire kit but I decided to use them on my build. I painted the bombs in only a slightly lightened RAF Dark green, then put on a gloss coat, then decals and finally a matt coat. The tail cones and fins for such bombs were often painted in either black or grey. I decided on black for greater contrast between the colours. I still have to weather them up. See pics below.
For the weathering I have only done the paint fading and the exhausts themselves thus far. To give you and idea of the extent of the fading, I placed one of the bombs on the fuselage to show the difference in what is almost pure RAF Dark Green (the RAF Dark green on the bomb was lightened a bit with white) and faded RAF dark green. I have seen some models where a lighter colour is sprayed inside of the original colour to give a faded effect but I wanted to achieve a uniform fade and besides I couldn't do this anyway as the decals were already on. I achieved this using filters which I have used often on my armour builds.
Next I have to add some paint chipping, dirt, exahust stains etc to finish her off. Then I will add the sticky out things once all that is done.
