Time to start all over again.
I checked the paint coat and it seemed pretty even to me, without too much damage. So i decided to spray Tamiya fine surface primer straight on it, without sanding. A good inspection of the primed surface showed that it was a bit rough, but I am not sure if this was because of the paint below it or just bad priming.
Today, my Christmas holiday started, which was a good time to start using the airbrush. The approach of painting is similar to the first attempt, as I was quite pleased with the result.
First i made a cow with Tamiya black:
Which I converted to a tiger with Tamiya Nato Brown:
I expected that the Nato Brown was a bit darker, because this is quite light. Well, tomorrow, the blue will be applied and as I am spraying light coats, i hope i can modulate it to my likening
The yellow tailband was also applied.The last time, i used Tamiya yellow green for it, but i found it a bit greenish, so now i mixed it with Tamiya lemmon yellow in a ratio of 1:2 (1 yellow green, 2 lemmon yellow) and the result is already better.
Tomorrow the blue coat and hopefully it will be as nice as the previous coat.
Jelger
