I'm back.
But for how long who knows.
It's weird we will go months no trouble and we get hit with the same issue but no one seems to know how to fix it properly.
I'll have some poor qa lit photos soon,taken on tablet until I can figure out how to transfer them from a camera to the tab.
Nothing is easy.
Oooh slight change of plans I'm going to a different Kiwi Corsair the 3 tone ain't working quite as well as I thought.
Would be ok with an airbrush but not working to well with rattle cans,Hmmmm airbrush and compressor or put said amount towards an 8Inch Dobsonian astronomical telescope.
Chris,
Does your tablet have any USB ports? if so, then you should be able to plug your camera into it as all cameras have a USB port or cable with a USB connector on one end. Transfer the pictures to your tablet, and go from there. The other option is to use an adapter for your cameras SD card that also plugs into your tablet via a USB cable.
Painting with rattle cans other then a one or two camo scheme isn't easy. You need to completely mask any areas as the spray pattern will go every where. The other issue is that your 3 or 2 tone camo pattern has feathered edges. You can accomplish that by using Blu-Tac or Silly Putty worms then masking tape that will also help hold those worms in place. Light even coats which isn't all that easy with a rattle can. Let dry, then re-mask for the next color.
Honestly, not having a air brush and compressor is a real disadvantage as you have literally no control over the paint pattern. The decision as to what to buy is yours, but not having a air brush/compressor really limits what you can accomplish as a serious modeler.
