This will be my entry for the very first group build I'm participating on.
First impressions on my initial test fits, this kit is going to be a challenge in terms of fitting and gap filling. I will be doing this OOB so the empty cockpit walls will have to remain empty. I think my major focus of learning here would be fixing the poor fittings. This tooling is way back from the '80s so poor fittings are not surprising at all.
For some reason the edges of the wings have yellowed a bit. No idea what caused that. The instructions are okay (not yellowed), so I think this is more from a recent production run. This tooling has been having reboxed released up to 2015, according to Scalemates.com
So we all start with the cockpit. And I present to you, probably the comfiest seats in Imperial Japan. The instrument panel has no decals, but surprisingly the dials are sculpted. I can probably try to do a little wash or something here to liven it up, but I won't spend too much time in the cockpit work. And sadly, the kit comes with a rear machine gun but no mount for it, and no mention in the instructions as well. Probably because there is no open canopy option.
God, this kit sure has a lot of fitting issues. It could be a contender for the forum's Hall of Shame but then this being my first circa '80s kit I won't make judgements.
So first I airbrushed the usual interior green on the cockpit areas.
Upon assembly, one can finally encounter the struggles. First, would be fitting the cockpit tub between the fuselage halves. That's centering the tub and making sure it's on the assigned grooves while holding two fuselage halves.
As the photo shows, I deliberately applied a lot of super glue to make sure the tub stays put. The fuselage halves won't sit flush together, so when the cement was dried I took some Tamiya putty to fill in the gaps, and then wet-sanded it once the putty has dried.
Now for the wings. Dry fitting shows two humongous gaps. I did a bit of sanding around the surfaces to be joined, applied cement, and assembled them together. The starboard wing seems okay, but the port side one still has the huge gap. That will have to be filled with putty on my next sitting.
