well, I did not start my vacation as expected, but I still managed to start with this kit. I got Broncos kit and a bunch of aftermarket stuff. Not all of it is useable so I will just take things that are adjustable for this kit:
For a full review I recommend reading Bret Greens reviews over at Hyperscale:
Bronco P-40C (Hawk 82-A2) Flying Tigers
Bronco Curtiss Tomahawk Mk.IIb
Furthermore the wings are bulbous .. this is hard to explain, it's shape is rather than an oval with an edge than a drop. So you have a lot of fun getting the thick rear edge thinned...
As per instructions I started with the wing. As I wanted to replace the control surfaces with the AML stuff, I had to cut out the ailerons.... you have some extra work when you use the wrong one for the wing, thus I had to add some white plastic sheet to fill the area again. Else this was straight forward.
As you can see I sanded the wigtips down as these were much to thick (see above re "bulbous") using the new aileron as a rough guide. I also glued the landing flaps shut.
Glueing everything together was easy and the clamps are just for adding pressure on the joints (the ailerons are just clipped in to check the fit)
The wing is ready and just has to be cleaned up. I hope to find some replacement barrels soon. Not sure what to use.
The flaps have no outer surface detail so these were ideal to sand down (a lot). Luckily the material are about a mm thick.
Still not perfect but I would have to wait fow a few weeks to let it fully harden and then sharpen it razorlike ... which I won't do.
So lets have a look at my favorite part of the build, NOT.
I testfit the rear wall of the Aires cockpit, but that would not fit. Luckily there is little detail on this thing and I just cut off the seat mount from the kit part and added it to the right fuselage.
The cockpit parts seem to fit very good which spares me some hefty grinding and sanding. I just removed all sidewall details and glued in the Aires sidewalls, Then the rear wall was lengthend (it is still about half a mm too short) and the tail wheel mounts were added.
Next will be adding the floor to get some stability into the fuselage. I still did not figure out how and where exactly the firewall with the engine has to be added.
all the best
Steffen
