European Union
KitMaker: 2,186 posts
AeroScale: 1,587 posts
Posted: Sunday, May 06, 2018 - 01:21 AM UTC
Silly trick:
If you need to sand in areas with panel lines, which then of course disappear, it may be worthwhile to deepen the existing panel lines before sanding en switch between sanding/deepening regularly. The existing lines are usually very good guides for deepening.
just my 0.01 cents
The mission: Beat the stash.
Almost conquered: MIG-29, Blackhawk, Skyray, Skyraider, fouga
Main battle:Demon, Skyhawk, F-14, CH-53
Stash reserve:Blackhawk, CH-46, 47 en 53; SU-7, Eurofighter, mohawk, hellcat, F-16D, 6x Fouga Magister, Voodoo
Texas, United States
KitMaker: 5,026 posts
AeroScale: 2,811 posts
Posted: Sunday, May 06, 2018 - 03:01 AM UTC
Drab, I thought about that, but since this is for a learning experience. Your tip will be taken up on later scribing tries, thanks for you input it helps.
The more I look at this Vintage Monogram Bf109 the more I think it will be worth some painting and good decals.
Bob
If it aint broke dont fix it.
Posted: Wednesday, May 09, 2018 - 06:41 AM UTC
Washington, United States
KitMaker: 3,670 posts
AeroScale: 833 posts
Posted: Wednesday, May 09, 2018 - 06:54 AM UTC
Bob,
Did you intend to engrave that deeply or is this just part of the experiment? I guess my comment would be panel lines should be a little more subtle, and less deep-- barely perceptible under primer and a couple of coats of paint-- those look pretty deep. What tool did you use to get these, or is it a combination of tools?
VR, Russ
Posted: Wednesday, May 09, 2018 - 08:01 AM UTC
Russ, this was/still is an experiment and I will use much less pressure next time.
Bob
Posted: Wednesday, May 09, 2018 - 07:48 PM UTC
Bob, I was thinking that. I use several tools when scribing panel lines. I've tried most of the commercial ones sold (except for MMRs-- which I'd like to try). I've found all of them a bit lacking so I've fallen back on just two. I really like using just the tip of the back of a B&B surgical blade (available from Squadron) mounted in thier cheapo handle. I also have a selection of dental scrapers (gleaned from my dentist who saves old worn out ones for me (along with old dental burrs). I take the old scrapers and probes and use my Dremel tool to grind ad polish them up into acceptable scribers. That way I can get whatever tip I need. I've found the LSP article (linked above) on the "Poor Mans Slotting File" to be very helpful as well, although I use super fine sandpaper glued back to back with CA, rather than the plastic he used in the article. I have a modeling friend who uses old airbrush needles for scribing and swears they are the best tool for fine lines (I don't go through airbrush needles that fast to use them though-- thank goodness!). I'm looking forward to your next scribing article!
VR, Russ
Posted: Wednesday, May 09, 2018 - 07:54 PM UTC
Russ, could you post a photo of your B&B surgical blade and handle?
Bob
Posted: Wednesday, May 09, 2018 - 10:04 PM UTC
Bob, I’m a Luddite when it comes to posting photos, but I’ll send a PM. The B&D blades are surgical blades with a slot in the end of the blade that goes in a “flat” handle. Squadron sells them.
VR, Russ
Posted: Thursday, May 10, 2018 - 06:09 AM UTC
Since these are test subjects I will stay true to Monograms vintage instructions color scheme for the 109 and Hurricane.
Posted: Wednesday, May 23, 2018 - 11:56 PM UTC
I pulled the airbrushes out after some 4-5 months and they did work well so back to the bench for a tear down and another clean up. The paint also was drying before it hit the plastic so more retarder. The weather here is very humid and the water filter was still spitting every so often.
Posted: Thursday, May 24, 2018 - 05:49 PM UTC
Bob,
Paint drying before it hits the model's surface which is thinned out correctly can be caused by other factors. Distance from the tip to the surface, and flow psi will also cause it.
On my Workbench:
Just Completed:
Posted: Sunday, May 27, 2018 - 09:38 AM UTC
Posted: Thursday, June 11, 2020 - 01:20 PM UTC
Posted: Thursday, July 09, 2020 - 11:44 AM UTC
I finally pulled the photo cube out and set it up, which I don't like to do. It is a pain with the cat just waiting for me to leave the room and use it as his bed.
Here are better shots of the Monogram Bf109E and the final result of my attempt at rescribing panel lines.
I was able to use the original decals.
