Comes along nicely, Tim. That aluminium underside looks quite unusual. How did you solve that problem with Klear you had?
After re applying the Vallejo Aluminium I sprayed a couple of coats of Vallejo gloss varnish [70.510] over the aluminium. I thinned the varnish a little with Vallejo thinner as it seemed a little on the thick side to me for the airbrush. Its a good gloss finish for applying the decals. Once the decals were applied I re-coated the model with Kleer including the aluminium areas without any problem.
Thanks for the tip for the spinner spiral masks the spinner Torsten. I will be ordering a set
