Early Aviation 1:48 Photoetch frets 101
Posted: Saturday, April 28, 2007 - 02:19 PM UTC
". . . To begin using Photo-Etch Brass you will need a few tools which you will probably already have. You will need a modelers knife with a sharp blade, a Swiss file, a pair of tweezers, something to cut on, and a pair of long nose pliers with smooth gripping surfaces (not textured). The smooth surface will not leave marks or deform the brass when you are working on it. Your cutting board should be of a hard substance that will not deform the brass when you are cutting on it, but will not dull your knife too quickly. I use aluminum but you could also use brass or wood. Kitchen cutting boards that come in wood or plastic are excellent and are quite cheap, but make sure the surface is flat and not textured. . ."
Posted: Wednesday, April 02, 2008 - 09:31 PM UTC
Just bringing this up for a fellow looking for PE. Another site where Part of Poland is sold is Misterkitusa.
http://www.misterkitusa.com
Posted: Monday, March 09, 2009 - 05:08 PM UTC
Greetings all just bringing this thread up for a fellow modeler
Kornbeef
KitMaker: 1,667 posts
AeroScale: 1,551 posts
Posted: Monday, March 09, 2009 - 07:03 PM UTC
It never hurts to do so Stephen
Posted: Friday, March 12, 2010 - 04:56 PM UTC
Again I had a request for this oldie but goodie. So here it is.
Posted: Monday, November 29, 2010 - 05:00 PM UTC
Since there are several projects I am working on that use PE I am bringing this up to post some images and for others to ask their questions. A thread for WWI PE.
Just a quick trip back into the ancient days when PE was just being introduced to aviation modelers. Rail road modelers first gave us PE and the "WWI aviation modeling Guru" of us all was ( and by rights still is) the good fellow Harry Woodman defined it. PE was never meant to stand alone. Often it must be thickend and given a round or oval crossection with expoxy ( no super glue back then) or plastic strip in halfrounds. Think of PE as the bare bones of the finished product you want to model.
Posted: Sunday, August 04, 2013 - 06:41 AM UTC
Here are some old favorites of mine. (Especiaslly with the early 800xx series Eduard Albatros D.V / Va kits.
