Oh don't forget to paint the radiator and oil cooler matrixs' and the inside of those parts aswell.
Ok Mal, but not quite sure which bits you mean exactly by the "inside of those parts", could you expand please? And what colour?
Priming, mmmm, I haven't found the need to prime my armour when using the Humbrol enamels, what would your advice be?
I have gut the protruding guns off and they are sanded flush with the wing front edge, what about finishing off this?
Should I paint the tail wheel assembly before attaching it?
Drilling for the wires.....If I have this right, I need to drill a 0.3mm hole in the centre of where the large O decal goes on the side of the fuselage. And where else?
Is the underneath of the plane Humbrol 90 Matt Beige Green?
Inside of the wheel wells are Interior Green - right?
Radiator faring and Oil cooler and carburettor intake themselves painted same as wing?
I know theres a lot of questions, but just want to be sure :-)
Roger
1) By the inside I mean the part of the radiator and oil cooler from the matrix the the outside lip. To be honest I don't know exactly what colour they shoul be. They could be Int green or undersurface colour. You cant see a lot once thy're in so safe bet would likely be undersurface colour. you will see I've sprayed mine Int Green but thats cos I was undicided at the time.
2) Priming, whell I never used to prime and as you are hand painting, as long as the plastic is clean, as you know and are used to it I would stick to what you know. When you get an AB we can disciuss it then. The reason I prime will be explaned in my article on pre-shading. Coming soon. :-)
3) If you are going to cover the gun ports with a red patch then, assuming the wings have the joint lines removed, then that should be it. Apart from this:
This is supposed to represent the wheel down lock indicator, a projection painted red, better represented by a small piece of wire, angled away from the fuselage. So if you want to trim this off, drill a hole and you can add the indicator later, after painting. I will try and find a picture.
Red patches were doped fabric, to prevent fod entering the guns and to help reduce drag. Until the guns were fired, of course.
4) No, tail wheel is the underside colour.
5) Not quite, the IFF wire on the port side leads in just behind the access panel and just below the level of the elevator, so it angles down very slightly. Starboard side similar. When drilling, start perpendicular, when you have a bite angle you drill back towards the tail. For the antenna wire, drill a hole behind the mast location, you can judge the position from the painting guide. I've just had a look at the box top painting and it does look as if the IFF wire leads in through the centre of the roundel, however ignor this drill as I suggest and position the decal (when we get there) without referencing to the position of the IFF wire. :-)
6) Yes if 90 Matt Beige Green is what we said was Humbrols "Sky".
7) Yes, interior of wheel wells are Int green.
8) Yes, the outside of the Radiator faring and Oil cooler and carburettor intake themselves painted same as wing.
No problem Roger.
Here's my progress:
Interior sprayed.
Interior Washed.
I found that I haven't got any etch belts left so I'm hving to scratch build them, using port bottle lead foil and etched buckles.
Mal
