Jean-Luc's hopefully got this beauty waiting for him for when he gets back from holiday, so watch out for his full Review soon.
Hi Rowan!
If "soon" means two months then it's ok...
I started the Fulmar kit and I will make an "out of the box" review build here if you don't mind. So far I completed the cockpit...
The interior detail is ok but I'm missing the resin and photo etched parts that can be found in most of the MPM kits. While the Fulmar kit seems to be easier to build than a typical short run kit, it is (unfortunately) also less detailed. It seems that the Czech manufacturer took a step forward the casual builder to the detriment of the detail freaks. It's a choice but personaly I regret it. Maybe they will do an "expert" boxing in the future... who knows.
While gluing the interior parts, I made a mistake (see red arrows). I placed the sidewalls to much behind and I had to cut the rear bulkhead so it could fit. This is my fault, I should have checked twice, but I can confirm what Rowan said, in some places the MPM instructions are rather vague. For example, there are no color instructions at all for the interior!? The builder is left on his own for the painting so don't take my model as reference... it's mainly guesswork! For the basic "Grey Green" interior color (thanks Rowan for the info about that), I used a mix recommended by Tamiya for their RAF kits (XF5:1 + XF21:3 + XF65:1) and then sprayed pure Sky (XF21) to achieve a lighter tone. After some drybrushing and a wash, the result is a rather indefinable and speculative color... exactely what I wanted!
Anyway, once completed, the interior looks not too bad and since I want to build the model with a closed canopy I think I can live with it. The only things I will add later are aftermarket seatbelts because there are none provided in the kit.
I also glued the wheel bays sidewalls in place and assembled the wings. The fit is good but you will need to add some putty if you want a clean result where the sidewall parts meet the lower wing part. Unfortunately, some details will get lost in the process if you are not carefull... like me.
I hope to glue the wings to the fuselage next. I already made some dry fittings and it looks promising!
