WNW GB 2009 -10 RFC Sopwith Pup - Des
New South Wales, Australia
KitMaker: 366 posts
AeroScale: 309 posts
Posted: Friday, March 12, 2010 - 09:24 AM UTC
Thanks for all the nice comments.
Carl.
The turnbuckles are my own, I always make my own turnbuckles, a detailed description on how to make them is on my web site, page 7.
http://ww1aircraftmodels.com The tolerances on this kit are excellent so far, looks like Wingnuts have made improvements in this area, I have had no problems with the fit of any parts.
You are correct in what you say, there appears to be a swing towards WW1 aircraft, and why not, they are beautiful looking aeroplanes.
Des
Check my site for 1:32 scale WW1 aircraft model build logs, build techniques, how to make turnbuckles and eyelets plus much more, plenty of photos of my finished models
Texas, United States
KitMaker: 365 posts
AeroScale: 356 posts
Posted: Friday, March 12, 2010 - 02:52 PM UTC
Carl.
Des
Des,
Thanks for the link to your excellent web site.I can see I'll be spending a lot of time reading through all the articles and future articles too.
Highest Regards,
Gregory Jouette
Posted: Friday, March 12, 2010 - 04:28 PM UTC
Thanks guys for your kind words, I will try my very best.
Mark.
You will find my full Bristol build on my web site at
www.ww1aircraftmodels.com
or it is here in the early aviation forum bottom of page 4.
If you are interested my Junkers build is on page 5
Des.
And you can see links to all GB participants
here on page 7 about halfway down Or under the GB home thread here on page 1 post #8. ". . .The most important thing is to know why you build and then get the most that you can out of building." via D.D.
KitMaker: 366 posts
Posted: Sunday, March 14, 2010 - 01:53 PM UTC
Another up-date on the Pup. The cockpit area is now complete and has been fixed to one half of the fuselage. The seat and seat belts are fitted as well as another turnbuckle and cable across the front of the instrument panel ( not a real safe place to put one, right in front of the pilots face, not good if he has to do a bad landing). I have also done a bit of work on the rear of the fuselage ready for the tail skid.
I started work on the rotary engine but have hit a problem, the intake manifold (or intake header assembly as WNW calls it) won't fit, the pipes are too short and don't reach the intake ports on the cylinder heads, I will have to do a bit of serious thinking about this one.....
Here are some photos of the completed cockpit.
Des.
Posted: Sunday, March 14, 2010 - 02:36 PM UTC
Posted: Sunday, March 14, 2010 - 03:19 PM UTC
Most excellent Des ! I really like the different tones of wood , makes this assembly stand out !
Arizona, United States
Posted: Monday, March 15, 2010 - 08:13 AM UTC
Great job so far. Disturbing news about the engine though.
We few, we happy few........
Indiana, United States
Posted: Monday, March 15, 2010 - 08:53 AM UTC
Looks great. I have bookmarked your website also.
KitMaker: 366 posts
Posted: Thursday, March 18, 2010 - 12:54 PM UTC
Thank you all for your kind words, they are much appreciated.
The engine is just about complete, still need to add the plug leads and to add "heat" stains to the intake pipes. I fixed the intake manifold problem by straightening the pipes a litte, then bending the pipes rearward to be in line with the cylinder heads, then put more of a bend in the top of the pipes. After all this there was still a gap between the pipe and the intake port on the cylinder heads so I cut some brass shim to 0.55mm x 1.9mm and inserted them between each pipe and the intake port, held it all together with a small drop of CA.
I have just about completed the rear section of the fuselage, still needs a coat of matt clear. Tail skid has a light wood colour, just need to finish it off. The fuselage is nearly at the close-up stage, this aircraft has the adjustable tailplane.
Here are the two fuselage halves ready for close-up. Both wings have had the pre-shading done as well as the tailplane. The colour here is CDL or Humbrol No. 121, same as the inside of the fuselage.
Hope to have some more done over the next few days.
Des.
www.ww1aircraftmodels.comCheck my site for 1:32 scale WW1 aircraft model build logs, build techniques, how to make turnbuckles and eyelets plus much more, plenty of photos of my finished models
KitMaker: 365 posts
Posted: Thursday, March 18, 2010 - 01:10 PM UTC
Des,
Outstanding project to date.Would the tail skid arrangement be the same on a Strutter as well? Been wondering how best to arrange the tail skid on my Strutter under construction for the Two Seater Campaign.
The engine sure looks excellent my friend,can't wait to see the finished element. Great photography too,I got to figure out how to get such clear close ups with my camera.
Regards,
Gregory Jouette
KitMaker: 366 posts
Posted: Thursday, March 18, 2010 - 05:37 PM UTC
Brad, over on the Drome, has pointed out an error I have made in the pre-shading, I have added a centre spar which should not be there, the Pup only had two spars running where the struts mount. I will rectify this error hopefully without having to remove all the paint and starting again.
This is a big oops on my part............sorry guys...
Gregory. Thank you for your comments. I don't know the arrangement of the tail skid on the strutter, I'm sure someone here will be able to help you with that question.
Des.
Milano, Italy
KitMaker: 642 posts
AeroScale: 382 posts
Posted: Thursday, March 18, 2010 - 08:31 PM UTC
Des!
great job as always! I like the engine very much! a real beauty!
KitMaker: 366 posts
Posted: Friday, March 19, 2010 - 12:07 AM UTC
Here is a photo of the corrected pre-shading, with only two spars. I managed to make the corrections without having to strip the paint off and start from scratch. Once the paint is dry I will give the wings a coat of clear.
Des.
Posted: Friday, March 19, 2010 - 12:13 AM UTC
Lookin Good Des: I like the engine, and for the problems you had with the intakes, it doesn't show. Good luck on the repaint, it looks great the way it is. You could say you have an exceptional pup in that the guy at the factory didn't get the word on the center spar until after it was done, so it is a one of a kind aircraft.
I am hoping I get mine today.
Addendum: The repaint looks as good as the original. Apparently the shop foreman wouldn't allow the third spar.
Posted: Friday, March 19, 2010 - 12:17 AM UTC
Just tuning into this now , excellent job Des ! I like the copper shade you used on the intake pipes . Is this acrylic or enamel paint ?
Florida, United States
KitMaker: 45 posts
AeroScale: 44 posts
Posted: Friday, March 19, 2010 - 07:21 AM UTC
Des - Your work never ceases to amaze me. I call it hi-fidelity workmanship.
Ron
KitMaker: 366 posts
Posted: Friday, March 19, 2010 - 08:34 AM UTC
Thanks so much for all the kind words.
Terri.
The paint I used for the copper look on the intake pipes was Gunze No. 215 Mr. Metal Color - copper. (brushes on beautifully)
Des.
KitMaker: 366 posts
Posted: Tuesday, March 23, 2010 - 08:26 PM UTC
Milano, Italy
KitMaker: 642 posts
Posted: Tuesday, March 23, 2010 - 09:06 PM UTC
Des!
I saw your site! it is very well done !
I'll watch it closely!
ciao
Edo
Posted: Wednesday, March 24, 2010 - 12:18 AM UTC
Sweet little build you got going there.
Posted: Wednesday, March 24, 2010 - 12:30 AM UTC
I second that Des .
In all this is turning out to be outstanding so far .
Posted: Wednesday, March 24, 2010 - 12:48 AM UTC
Looking good Des: I like the counter shading. I will try your methods on this build when I start on it. I picked up on your counter shading of the outer skin as well. Just subtle enough to see the variations.
KitMaker: 365 posts
Posted: Wednesday, March 24, 2010 - 02:51 AM UTC
Des,
Excellent project my friend. Love the counter shading,very subtle. Which marking will you be using? Thanks very much for this thread.
Highest Regards,
Gregory Jouette
KitMaker: 366 posts
Posted: Wednesday, March 24, 2010 - 09:02 AM UTC
Thanks everyone for your kind words.
Gregory. The markings will be;
A6156 "OS", Whitehead built, 54sqn, Lt. O. Stewart, April - May 1917.
Des.
http://ww1aircraftmodels.com Check my site for 1:32 scale WW1 aircraft model build logs, build techniques, how to make turnbuckles and eyelets plus much more, plenty of photos of my finished models
Merlin
Senior Editor![KitMaker Network Subscriber](../images/global/km_subscriber_small.gif)
#017
United Kingdom
KitMaker: 17,582 posts
AeroScale: 12,795 posts
Posted: Wednesday, March 24, 2010 - 09:25 AM UTC
Hi Des
Fantastic work! A real inspiration!
I'm going to have to build a little kennel... I got confimation that my RNAS Pup is being delivered tomorrow.
BEWARE OF THE FEW...
