Hobbycraft 1/48 Me109K "The last of the last
![KitMaker Network Subscriber](../images/global/km_subscriber_small.gif)
#305
Christchurch, New Zealand
KitMaker: 1,673 posts
AeroScale: 1,517 posts
Posted: Tuesday, December 29, 2015 - 03:07 PM UTC
A smidgen of progress on the Bf109K-4 got the canopy masked and painted. The wheel wells, wheel covers, prop boss, landing gear covers painted. I've painted the spine and the underside of the fuselage which shows me I need to do a little filling and sanding before painting.
Posted: Thursday, December 31, 2015 - 03:55 AM UTC
Chris,
The little bit of extra time now spent, will pay big dividends in the finished product.
On my Workbench:
Just Completed:
#305
Posted: Saturday, March 05, 2016 - 11:32 AM UTC
#424
Queensland, Australia
KitMaker: 4,648 posts
AeroScale: 1,938 posts
Posted: Saturday, March 05, 2016 - 12:35 PM UTC
Looking good, Chris. Been waitin' fer ya to get her done.
Gary
Frederick The Great
#305
Posted: Saturday, March 05, 2016 - 03:17 PM UTC
Sorry for the delay buddy but I'm back in the swing let's see how she looks once I'm done with her.
Posted: Sunday, March 06, 2016 - 08:34 AM UTC
Chris,
Your making excellent progress with the decaling. From my view it sure seems like you eventually got them to lay down just fine.
On my Workbench:
Just Completed:
Bayern, Germany
KitMaker: 673 posts
AeroScale: 492 posts
Posted: Sunday, March 06, 2016 - 12:39 PM UTC
Coming along nicely Chris, and I agree with Joel, I think the decals look just fine.
#305
Posted: Sunday, March 06, 2016 - 02:30 PM UTC
Hi Ernst & Joel my thanks for the positivity!
Well yes they are stuck down well but what you don't see was the patient struggle to get them that way! The "IngeBorg" decal broke around the B and flipped 180 degrees and promptly stuck to itself! I put it back in the water and managed to tease it apart and realign everything got it back onto some decal paper and realized that it was inside out so to speak. That's okay I figured I could stick it to a slight pool of "Klear", the reality was it had a greater affinity for the decal paper than my pool of "Klear". I managed to get it onto another piece of decal paper this time the right way round and slide it off onto the kit. I then gently maneuvered it into position and promptly quit all decaling till it was dry.
I've tried warm water, hot water and cold all provide similar results. The decals don't exactly float off the paper as most other decals do and adding a little setting solution helps with sliding it off the paper and onto the kit but the curl persists. I am toying with the idea to applying a little softener to see if that will temporarily allay the curl but I know from past history that Hobbycraft decals stretch wildly if you try to maneuver them after softener has been applied.
So I think I'll persist in slowly working through the decals and get them applied little by little. They have supplied the swastika however it's a multi part affair with both arms separate and the white outline separate as well. So that's four pieces per swastika. Getting everything satisfactorily lined up is a bit of a guess. It may be slightly out but I hope it won't stick out like dogs bollocks once finished.
#305
Posted: Friday, March 25, 2016 - 04:00 PM UTC
Posted: Friday, March 25, 2016 - 07:01 PM UTC
Chris,
You're making excellent progress, and that's what counts, not the speed that you get there. Heck, I model a lot, and don't have much to so for it most of the time, but I eventually get there.
Decaling looks good. Believe me I feel your pain and frustrations as I've been fighting with the Academy decals for the B-25B, and nothing in my decal arsenal had any effect on them. So I'm buying Mr. set and Mrs. Sol which according to my brother work well with the Chinese decals.
Nice job on the recessed panel lines. They look perfect.
On my Workbench:
Just Completed:
#305
Posted: Friday, March 25, 2016 - 11:21 PM UTC
Thanks Joel coming from you the compliment means a lot.
I solely use Micro set and Micro sol on my decals and have mixed results depending on the manufacturer. Some of the Chinese/Korean decals seem practically impervious to just about anything. I have even read blogs where some have used Tamiya thin cement or similar solvent to soften decals to get them to settle in/over detail. HobbyBoss's decals though have given me very little trouble, I have built several of their kits with no issues ... yet.
I have also had issues with decals from ICM (brittle), Hasegawa (some very thick & inflexible), most of the earlier Airfix kits although the newer releases seem very much better (silvering, not settling well). Early Monogram decals settle well with MicroSol but are very thick, still quite visible after a matt coat.
Most aftermarket decals I have used have needed little "extra" help to settle well over the model. But some have been very thin and brittle. It's obviously not an easy road to find the perfect decal medium.
Anyway I'm in the home stretch now just some weathering to accomplish, some details to paint and some final assembly and I'll be done.
Posted: Saturday, March 26, 2016 - 06:11 PM UTC
Chris,
Our lives would be that much easier if all manufactures used Cartograf. AM decal makers on the whole have outstanding decals, and I've yet to have any issues with them. Of course, I tend to stick to just a half dozen different AM companies.
On my Workbench:
Just Completed:
#424
Posted: Sunday, March 27, 2016 - 02:22 AM UTC
Hi Chris,
Your 109 is really looking great! I recently had a bad experience with ICM decals. The only set I could find online that had everything I wanted were by Techmod. They were thin and delicate, but sunk right into the details by the time they were dry. I didn't use any decal softener on them.
Because they were very thin, I floated them onto a big bead of water wherever I put them. Positioned them, blotted them down, and that was it. I was really impressed with them.
Gary
Frederick The Great
#305
Posted: Sunday, March 27, 2016 - 03:29 AM UTC
I agree with you Gary I used Techmod decals on a PZ.11c build I did and while care was needed with them because of the frailty they stuck like s$%t to a blanket and conformed beautifully over surface detail.
JPTRR
Managing Editor![KitMaker Network Subscriber](../images/global/km_subscriber_small.gif)
#051
Tennessee, United States
KitMaker: 7,772 posts
AeroScale: 3,175 posts
Posted: Sunday, March 27, 2016 - 07:38 AM UTC
Chris,
You are showing the potential of the old H.c. models. Great work.
1/8 scale BMW R75 by Bandai
Did you mean 1/48?
If they demand your loyalty, give them integrity; if they demand integrity, give them your loyalty.--Col John Boyd, USAF
“Any plan where you lose your hat is a bad plan.”
#305
Posted: Sunday, March 27, 2016 - 11:02 AM UTC
Thanks Frederick! While I think Hobbycraft kits are often underrated they usually give quite a good base to start from. The cooper details set really set this kit off beautifully.
Nope 1/8th! I built a 1-9th scale Zundapp for a friend and 1/8th BMW R75 was my "payment" for building the kit. They were his Dad's who passed recently and he wanted them built for sentimental reasons.
Bayern, Germany
KitMaker: 673 posts
Posted: Sunday, March 27, 2016 - 09:49 PM UTC
Nice work on the 109 Chris. I hear you about the decals, I have my trails and tribulations with them myself. Joel is right about Cartograph decals, they are the best for me and I can always achieve good results with them. The Zundapp looks outstanding by the way!
#305
Posted: Sunday, March 27, 2016 - 11:52 PM UTC
HI Ernest! Thanks for the compliment. The motorcycle is actually the BMW R75 although I think I have pics of the Zundapp somewhere if you're interested. (I'd have to go hunting through my folders to find them LOL)
I wholeheartedly agree about cartograf decals I've never had any issues with them. Always in register always behave impeccably.
#305
Posted: Thursday, March 31, 2016 - 11:06 AM UTC
#305
Posted: Friday, April 01, 2016 - 02:02 PM UTC
Nordrhein-Westfalen, Germany
KitMaker: 671 posts
AeroScale: 614 posts
Posted: Friday, April 01, 2016 - 04:17 PM UTC
Sorry to see this Chris.
I had a similar problem with the canopy of my Panther. After the fogging was compete hardened I used a cotton swab and applied it into a drill machine. The swab was coated with tooth paste and then The inside of the canopy was polished. But You have to use a rather slow rotation speed, so the canopy cannot be damaged by friction heat. After this You can additionally dip the canopy in future or klear. Maybe it is worth a shot before You dispose the canopy.
All the best!
Oliver
Posted: Friday, April 01, 2016 - 07:17 PM UTC
Chris,
That certainly is something that none of us want to see on your model or ours. That's one of the reasons why I don't use CA glues for clear parts as they're known to cause fogging. Rather, I use Tamiya Extra Thin very carefully applied and capillary action does more then 75% of gluing all the surfaces. The Extra Thin never has fogged any clear parts, but will instantly cause spot damage if you get it where it doesn't belong.
You should be able to remove the canopy with a debonder. Try to get one by the same manufacture of the CA glue you used. Not all are the same, or so I hear.
Polishing off the fogging is a viable 1st decision as CA glue doesn't melt plastic, so it's all on the surface. It was a bonding type glue, the damage wouldn't be fixable without removing all the affected areas, and that's a job that's nearly impossible on a canopy to do without causing more issues.
Once cleaned of the fogging, polish to smooth the surface out, but using a clear sealer on the inside surface won't have any visual effect as you're viewing it from outside in,. So strip off all the paint and then dip the whole canopy in Future/Pledge. If you used Acrylics it's easy to remove the paint. If not, it may be easier to just mask using the paint as a guide.
On my Workbench:
Just Completed:
#305
Posted: Saturday, April 02, 2016 - 02:24 AM UTC
@Oliver:Thanks Oliver it's something to consider, I've used tooth paste before with mixed results.
@Joel: The canopy was glued into place with Tamiya extra thin cement Joel, however the gun sight was glued in with CA and I hadn't left enough time for it to cure apparently. Sorry Joel severe lack of information in my post. Since Falcon canopies is in Wellington (North Island I'm in the South) it'll be rather easy and cheap to simply replace the offending article.
#305
Posted: Saturday, April 09, 2016 - 03:49 AM UTC
Well the weekend started out with such promise! I'd found myself a canopy to replace the one fogged, removed said canopy with a minimum of fuss and no damage to the airframe. (Bonus!) The replacement canopy from the Academy kit was very thin and crystal clear, in fact so thin I broke it in half whilst masking it. D'oh!
So now I'm going to try to fix the original canopy because I've no idea when the replacement from Falcon will arrive.
Posted: Sunday, April 10, 2016 - 10:01 PM UTC
Chris,
Your luck sounds a lot like mine of late.
Try very lightly sanding the fogged areas with nothing courser 2,000, then polishing through 12,000 grit if you have them, or use a non gel toothpaste, or my go to for final work a car scratch remover polish. Finish with a Future/Pledge bath, and you should be just fine.
On my Workbench:
Just Completed:
