1⁄35French Rescue Goose
15
Painting the interior
After all this time consuming work, I was happy to begin painting. I decided to go for the typical "Chamois" interior color of French planes as it would give a nice contrast to the Dark Blue exterior. I first sprayed Tamiya's Dark Yellow acrylic paint (XF60) on all the interior parts (picture 8). Then I drybrushed them with Humbrol enamels (a mix of white, flesh and khaki). Tamiya acrylics are almost "undrybrushable" (I found a new word!) and Humbrol paints are better for that. Then I added a wash of tinted Future (Klir in France) and painted the details. The result, as you can see on pictures 9 and 10 is quite amazing! Not that I'm an interior specialist, but with only an average paint job, the resin parts just look fantastic! I made a last picture of the interior before closing the fuselage... at least I have a photo as testimonial for all the work (picture 11).Closing the Box
Now comes the most difficult part of the kit: getting the fuselage halves together! With that much resin parts inside, you can imagine there's not much room for adjustments. I often used the words "test-fitting" in the review and I think it's the key to any succesfull short run kit build! Signifer's Goose falls in that category and you'll have to test fit everything to avoid nasty surprises!I used the following sequence (picture 12):
1 - First I glued the windscreen (after masking it) to one of the fuselage sides. 2 - Then I added the inside sub-assemblies. The windscreen is quite thick so you will have to adjust the top console of the cockpit as there is not enough space left. 3 - The fuselage halves are glued together and the resulting gaps (1 mm) are closed with spare plastic. 4 - The windscreen is adjusted and everything is held in place with strong clamps.
On the last picture you can see the result. I think it is acceptable. The wings were then glued in place and I found no real problem here... at least no problem that couldn't be resolved with a little bit of filler.
The resin elevators lost their hinges during the "cleaning" process so I made new ones before getting them in place (picture 13). Picture 14 shows the Goose almost ready for painting. You can see the areas were putty was used. But at least it looks like an airplane and not like a bus anymore.
Simply stunning! I cant wait to see what you build next. Congrats on a job well done!
OCT 15, 2005 - 05:52 AM
Hi all!
Thanks Dave, Rob and tapper...
My next build? A Tamiya 1/48 Schwimmwagen... my first vehicle since I build the whole Matchbox armor line more than 20 years ago! Maybe I will switch to armor now?
OCT 15, 2005 - 11:40 PM
Hi Jean-Luc,
The Goose! I tend to like floaty-boaty wingy-thingies and the Goose and the Duck are two of my favorites ,
Thanks for this article. Both the model and article are very enjoyable. You did a fabulous job on this bird
OCT 28, 2005 - 11:48 AM
thats one pandoras box that was worth opening! the tape on the tyres is a neat looking idea, and how did you get that drill into that cocktail stick?
if you switch to armour ill miss my sparring partner! (although i have a tamiya 250 halftrack, and a railway "tank" from revell!)
OCT 29, 2005 - 01:07 AM
Thanks Fred and Rick!
Phil, I first drilled a hole in the cocktail stick using my Dremel then put the drill in it wich I secured with CA glue... voilą!
I seize the opportunity of this message to say that Signifer added a link to my review and feature of the Goose on their website. Maybe this will help Armorama to have more French readers...
OCT 30, 2005 - 08:38 PM
Great plane and great review! I immediately ordered it through Hobbyeasy in Hongkong (which by the wauy is a GREAT webstore and cheap!! Thanks Jean Luc!
NOV 11, 2005 - 08:46 AM
Hi Michiel!
Thanks for your kind words! I wish M. Meissonier (owner of Signifer) could read such posts! :-)
NOV 11, 2005 - 09:55 AM
Awesome! Congratulations Jean-Luc!
It's great to know Signifer recognize the superb work you're showing here.
NOV 11, 2005 - 10:02 AM
Wow thats one fantastic kit you made there Jean-Luc. Back when i was building planes, the part i dreaded most was to place both halves of the fuselage and many a times given up on a model at that point.
Fantastic tutorial and one for the bookmarks.
NOV 11, 2005 - 10:17 AM
A superb model and review. A good couple of pointers there for the inexpierienced builders amongst us (me included). Ted absolutely GENIUS with the tyres, i wouldn't have thought of that in a thousand years.
Thank you Ted and Rowan.
Andy
NOV 11, 2005 - 10:34 AM
Copyright ©2021 by Jean-Luc Formery. Images also by copyright holder unless otherwise noted. The views and opinions expressed herein are solely the views and opinions of the authors and/or contributors to this Web site and do not necessarily represent the views and/or opinions of AeroScale, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of AeroScale. All rights reserved. Originally published on: 2005-10-15 00:00:00. Unique Reads: 19250
