1⁄35French Rescue Goose
15
Final assembly
The main work being done, it was time to finish the model. I noticed on my reference picture that the plane's tyres had treads and the kit ones none. I tried a new technique (at least for me) and used thin stripes of Tamiya masking tape (picture 21 and 22). The result was very convincing for a first try! As it is a relatively easy method, it's something I will do again rather than buying expensive resin replacement wheels. The remaining parts where then glued in place: engines, engine cowlings, landing gears, propeller, antenna mast, access doors, position lights etc... (picture23)While looking at the model I thought it was a pity to see all the rivets disapearing under the dark paint. I decided, using my smallest brush, to paint them one by one on the plane! I know it's a little bit masochistic but the result, after another coat of blue tinted future, was worth it (picture 24 and 25). Needless to say that I painted the rivets in several sessions so's not to go crazy! Usually, when you do this kind of boring job, you want to go faster and faster and you mess up everything after a while... so my advice would be: "Chi va piano, va sano!"
Last touch was to add light grey pastel powder behind the engines to simulate the dirt produced by the exhausts (picture 26).
Conclusion
Was it an easy kit? Certainly not! Was it a good kit? Definitely yes!Signifer's Goose was one of the most challenging kits I've built so far. I wouldn't recommend it to a beginner as some modelling skill is required that one can only gain after a few years of practice. But once finished, the model will be a masterpiece to display in your collection. Higher skilled modellers can even make a "Museum Quality" model out of it! But before you give it a try, ask yourself that question: "should I open Pandora's box or not?"
I would like to thank Tigercat (David Moulden) and Polarbear for their support while building the kit for the "Medics" Campaign! They both were of great help!
Simply stunning! I cant wait to see what you build next. Congrats on a job well done!
OCT 15, 2005 - 05:52 AM
Hi all!
Thanks Dave, Rob and tapper...
My next build? A Tamiya 1/48 Schwimmwagen... my first vehicle since I build the whole Matchbox armor line more than 20 years ago! Maybe I will switch to armor now?
OCT 15, 2005 - 11:40 PM
Hi Jean-Luc,
The Goose! I tend to like floaty-boaty wingy-thingies and the Goose and the Duck are two of my favorites ,
Thanks for this article. Both the model and article are very enjoyable. You did a fabulous job on this bird
OCT 28, 2005 - 11:48 AM
thats one pandoras box that was worth opening! the tape on the tyres is a neat looking idea, and how did you get that drill into that cocktail stick?
if you switch to armour ill miss my sparring partner! (although i have a tamiya 250 halftrack, and a railway "tank" from revell!)
OCT 29, 2005 - 01:07 AM
Thanks Fred and Rick!
Phil, I first drilled a hole in the cocktail stick using my Dremel then put the drill in it wich I secured with CA glue... voilą!
I seize the opportunity of this message to say that Signifer added a link to my review and feature of the Goose on their website. Maybe this will help Armorama to have more French readers...
OCT 30, 2005 - 08:38 PM
Great plane and great review! I immediately ordered it through Hobbyeasy in Hongkong (which by the wauy is a GREAT webstore and cheap!! Thanks Jean Luc!
NOV 11, 2005 - 08:46 AM
Hi Michiel!
Thanks for your kind words! I wish M. Meissonier (owner of Signifer) could read such posts! :-)
NOV 11, 2005 - 09:55 AM
Awesome! Congratulations Jean-Luc!
It's great to know Signifer recognize the superb work you're showing here.
NOV 11, 2005 - 10:02 AM
Wow thats one fantastic kit you made there Jean-Luc. Back when i was building planes, the part i dreaded most was to place both halves of the fuselage and many a times given up on a model at that point.
Fantastic tutorial and one for the bookmarks.
NOV 11, 2005 - 10:17 AM
A superb model and review. A good couple of pointers there for the inexpierienced builders amongst us (me included). Ted absolutely GENIUS with the tyres, i wouldn't have thought of that in a thousand years.
Thank you Ted and Rowan.
Andy
NOV 11, 2005 - 10:34 AM
Copyright ©2021 by Jean-Luc Formery. Images also by copyright holder unless otherwise noted. The views and opinions expressed herein are solely the views and opinions of the authors and/or contributors to this Web site and do not necessarily represent the views and/or opinions of AeroScale, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of AeroScale. All rights reserved. Originally published on: 2005-10-15 00:00:00. Unique Reads: 19250
