1⁄35F14A Tomcat - PART TWO
2.
Using my air brush, I paint the entire cockpit
in whatever base color is most prominent. I do not "scale effect" this base
color in the cockpits for two reasons. The first is functional -- I need to be
able to touch-up the color as I continue the cockpit painting process. "Scale
effecting" produces a custom mix color that will make touch-up painting
difficult to blend in. The second reason is theoretical -- most people will view
the model's cockpit from a range of less than 12 inches. The scale effect at
that distance is not as noticeable as it would be on the entire model viewed
from a distance of 24+ inches. Whether you are a believer in "scale effect" or
not, these are my reasons.
For the Tomcat, the primary interior color is Dark Gull Gray (F.S.36231).
Applying this overall color is the only airbrush work I do in the cockpits
(besides clear gloss and clear flat coats). The rest of my work is done using
3/0, 5/0, and 10/0 paintbrushes. I allow the cockpit to dry a full 24 hours
before continuing as brush painting over the base color before it fully dries
can lift it and mar the other colors that I am going to use.
