betheyn
Senior Editor
#019
KitMaker: 4,560 posts
AeroScale: 2,225 posts
Posted: Wednesday, September 12, 2007 - 01:27 AM UTC
The P-47 is really coming together nicely now Nige. I am looking forward to seeing this finished.
Regarding primer for Alclad paints, I always use Tamiya X1 Black acyrlics, and never had a problem so far.
This kit was painted in about a day with several different shades of Alclad over the Tamiya Black.
Andy
It's not the same, better, but not the same...
#029
KitMaker: 6,249 posts
AeroScale: 3,270 posts
Posted: Wednesday, September 12, 2007 - 05:30 AM UTC
I dunno about painting a kit in a day!,,its taken me the best part of a week but finally I can put the Alclad away.
Various panels have been painted in different shades of Alclad. What I love about this stuff is that different shades refelect light in different ways and as you move the model around the NMF appearance changes.
Im taking a break from masking for the rest of the day now, and I'll probably work on the undercarriage and prop for a while now before tackling the blue ID stripes.
Nige
Rigas, Latvia
KitMaker: 268 posts
AeroScale: 245 posts
Posted: Wednesday, September 12, 2007 - 08:12 PM UTC
#029
Posted: Thursday, September 13, 2007 - 05:48 AM UTC
Nice Mustang!,,Thanks for the link
Just a small update.
Anti glare panels on.
Nige
Östergötland, Sweden
KitMaker: 1,058 posts
AeroScale: 1,004 posts
Posted: Thursday, September 13, 2007 - 06:19 AM UTC
I like that finish, very shiny. But are you going to weather it, or will It be in this
Whats your style on this Nigel?
Awsome. This is a nice piece of snack(1/48) before the big dinner(1/32)
Lars Q
#029
Posted: Thursday, September 13, 2007 - 08:35 AM UTC
Lars Q
Hi Lars.
Thanks
Plans at the moment,after decalling, are to give the airframe an oil wash and then Klear it again.Then I'll reverse mask and spray the decals and antiglare etc in matt varnish.Then I'll see how it looks. I may end up misting on some heavily thinned Tamiya Smoke to blend it all together.
Actually,this isnt even a snack(1:48),,its only a nibble,,its 1:72 scale!
Nige
Oklahoma, United States
KitMaker: 6,043 posts
AeroScale: 80 posts
Posted: Thursday, September 13, 2007 - 11:01 AM UTC
Looking good.
still following along.
So how do you all shoot the upper and lower at the same time?
Can't see noway to hold it or turn it.
Does this Alclad Primer dry that Fast?
Thanks again
Posted: Thursday, September 13, 2007 - 06:59 PM UTC
1/72 Okey Nigel Then you have my deepest respect .
Sorry
But still I´m like your Jug.
Lars Q
#029
Posted: Friday, September 14, 2007 - 12:37 AM UTC
Thanks guys.
Hi Jeff.
The Alclad itself is supposed to be dry (according to their website) in about 10 minutes, but I leave it at least 90 minutes before I touch it.
Naturally its not possible to spray both upper and lower surfaces at the same time. What I do is sit the model right way up, and spray the upper surfaces and as much of the sides as I can. After a couple of hours I turn the model over and spray the underside. I sit the model on a piece of kitchen towel so I can move the model around without actually touching it during this process.
Hope this helps.
Nige
AeroScale: 80 posts
Posted: Saturday, September 15, 2007 - 12:05 AM UTC
Thanks again Nige.
Sorry about all the NOOB questions.
But as a lame excuse I have never used this here paint before.
I might be able to try mine soon.
Just need to fiddle these PE seat belts in after I glued the cockpit together.
Another lame question I bought a set of Resin Barrels but my LHS guy ordered a set for the {M version P-38 }these have like Muzzle deflectors on them safe to use or a No-No.
If I don't get an answer will make a separate post.
#029
Posted: Saturday, September 15, 2007 - 08:04 AM UTC
Hi Jeff.
The only dumb question is the one that isnt asked
Best of luck trying to get PE belts into an already assembled cockpit.I dont envy you there
Let me check my references about the resin barrels and get back to you.What version are you building?
Oh yeah,,,an update!
After two long masking sessions Ive finally finished spraying the ID stripes.
Next up will be a Klear coat and then its decalling time
Although these were supplied as decals in the AM set Im using they look so much better painted on I think.
Nige
Slovenia
KitMaker: 6 posts
AeroScale: 5 posts
Posted: Saturday, September 15, 2007 - 10:55 AM UTC
A fantastic job till now
AeroScale: 80 posts
Posted: Saturday, September 15, 2007 - 11:14 PM UTC
#029
Posted: Sunday, September 16, 2007 - 05:32 AM UTC
Hi Jeff.
The P-38 M's were converted P-38 L's. As far as Im aware (my reference material on Lightnings is quite limited), the M model was the only one to be fitted with the muzzle fairings on the gun barrels.These were fitted to reduce glare when the guns were fired.
Dont take this as gospel though,as I may well be wrong on this.
Nige
AeroScale: 80 posts
Posted: Sunday, September 16, 2007 - 10:16 AM UTC
Hi Jeff.
Nige
You are right on it and not even used that much as war was coming to an end.
The night Fighters
I have already started to drill out the Kit barrels .
Not that bad with a little patience.
Thanks
AeroScale: 80 posts
Posted: Tuesday, September 18, 2007 - 09:53 PM UTC
So how is this Plane coming along?
#029
Posted: Wednesday, September 19, 2007 - 08:03 AM UTC
Slowly
Nige
#029
Posted: Wednesday, September 19, 2007 - 08:54 AM UTC
#029
Posted: Thursday, September 20, 2007 - 05:48 AM UTC
Short update.
All the decals are finally on,which turned into a bit of a battle in itself but is finally over
While Im waiting for the coats of Klear to cure so I can start the oil washes Ive finished the undercarriage.Only additions here are some brake lines from black coated fine wire. Thankfully,thats the last of the extra wiring detail.
Nige
AeroScale: 80 posts
Posted: Thursday, September 20, 2007 - 12:15 PM UTC
Looking Good.
Great job on this plane.
Can't wait to see it finished.
Great work Nige
#029
Posted: Friday, September 21, 2007 - 05:03 AM UTC
Getting close to finishing now.
Ive given everything a wash of Burnt Umber oils.Although Im pleased with the effect Im going to add another wash in selected areas just to bring the panel lines out a little bit more.
Nige
#029
Posted: Monday, September 24, 2007 - 09:09 AM UTC
Progress has been slow the last few days as my attention has been taken up by a much larger P-47!
Last photo before finishing.
The past few days have been spent masking (more masking
) and matt varnishing the blue bands and anti glare strip. I added more wash also. I really like the way the burnt umber wash looks on the nmf. All the fiddly bits are now painted and hopefully I'll get these attached tomorrow and if the lights good I'll post some finished pics.
Nige
Illinois, United States
KitMaker: 537 posts
AeroScale: 437 posts
Posted: Monday, September 24, 2007 - 11:14 AM UTC
Hey Nige,
Your Thunderbolt keeps looking better and better
You must have really good and steady hands for the great work you do on such a small scale. I mean that sincerely !!
I see one thing you may not have thought of for adding to really complete your P-47. Hope you don't mind, but I took the liberty of modifying one of your pictures to show you what I am talking about.
You forgot to add the ace pilot worrying if he is going to be ready for the next sortie.
Sorry ...but I looked at the picture of your plane and then just happened to glance at your pic and the idea came to me. The two pics just went together so nicely. I couldn't resist the temptation. All in fun
If the enemy is in range, .....so are you!
#029
Posted: Monday, September 24, 2007 - 10:07 PM UTC
Hi Wayne.
I used to have steady hands but not any more,,Im laughing too much
That has to be the most unusual post Ive ever seen on Aeroscale
Right,,off to the bench to get this done!
Nige
AeroScale: 80 posts
Posted: Monday, September 24, 2007 - 10:21 PM UTC
Coming along fantastic.
Can't wait to see it done.
