Hi all!
Thanks for your kind words.
I think - can't say for sure - that the vermicelli bird may have been 70/71/65 with the overspray done in a light sand - exact shade unknown. Never seen one done like Tamiya's instructions.
Huh! I think it's to late to do a 70/71/65 camouflage for my Storch. I already sprayed the basic colors.
Here are two more pictures I found in my refs of desert vermicelli Storchs...
I'm not sure it was a RLM 70/71 with with light sand overspray. But I'm not sure it was a RLM65 over light sand overspray neither. On the second picture it looks more like the second alternative to me. Note also the dark color of the interior when compared to the external camouflage. Both aircraft are not the SF+RL Storch though. I will do as per instruction and blame Tamiya if it's wrong!
I glued both wings together. Fit is so good that almost no glue is needed for this operation. I only applied some on the clear roof part. I didn't used any on the metal spars. I think Tamiya's found an "idiot proof" solution to glue the wings to the fuselage on this kit...
Before painting the camouflage colors, I sprayed a coat of RLM02 over the glazings. Then I sprayed the underside blue (Tamiya XF23). I first pre shaded the model, then applied a coat of light blue and finally blended evertything together with another, lighter coat...
When the blue paint was dry, I masked the underside and applied the sand color. I didn't pre shaded the model this time because the vermicelli camouflage will hide everything anyway. I will rather post shade the model once the camouflage is done...
Nigel, yes, the model will probably appear in the french Tamiya Mag. But the article will focus on the diorama aspect since I'm building Rommel's SdKfz Greif as well.
Ok, now on to the vermicellis...
