I had got stuck at fitting the coming from the MDC cockpit detail set because the gun sight protrudes through it and therefor it had to be alighned correctly. Having cut off the original I realised that I had cut away too much, so the rebuilding began. Off course this became the hurdle that I had to get over to continue the build, which I managed to do this last week end. I have also finished the cockpit interior which I am about to insert into the fuselage.
This shows the amount of the cock up.
This shows the coming fitted and filler applied.
I made the seat belts out of Port bottle foil (From my Senior Drill Course) and etched buckles. The etched buckles came with the MDC set, which also contains a set of etched belts. I much prefer to use the etched buckles as the belts look far more realistic.
The belts painted. Humbrol "Authentic" HU10 (FS36622)
The belts weathered and fitted into the cockpit tub, the shoulder straps are realistically attached to the rear bulkhead.
Another view of the tub, showing the instrument panel. The dials are decals, again part of the cockpit set.
Mal
