I will be joining this group build with Roden's Beautiful Albatros D.III OAW. Special thanks go to Fliegermeister Stephen Lawson and Roden, who sent this wonderful kit to me for this GB.
Click Here.
Now to answer some of your questions. I will be doing the red and white candy stripe scheme depicted on the box.
I will be using the Eduard PE set for the Roden Albatros D.III. But the wing radiators on the OAW version are different from the original release, so I already know some of the parts won't match up. But most of them will.
The OAW kit looks to be the same as the original release, but there are some version specific differences. The first thing that struck me was that the OAW release is molded in a light gray, instead of the usual light beige color. I also believe some of the details seem to be sharper in the OAW release.
The "A" sprue containing the odds and ends parts is unchanged. The engine sprue "Z" has also remained unchanged. This is a good thing becuse the engine is a little gem. It was also used in the Pfalz D.III. The sprue with the wheels, horizontal stabilizers, and Spandaus, sprue "D" also remines unchanged. The sprue with the fuselage halves was the "B" sprue is now the "C" sprue, and has changed considerably. First, the fuselage halves themselves are different. They have updated panel lines, a squared of footstep, and engine compartment vents that are more detailed. The front deck over the engine compartment is also updated. We now have a small aero fairing over the axle, a rounded rudder and only one propeller. Other changes on this sprue are the larger wing root fairings and radiator pipes The wing sprue which was the "E" sprue, has become the "F" sprue, and now has larger radiators.
All that being said, I think we can expect this kit to build up as good as its predecessor. I hope to start on the engine soon. But I will heed the call of the links first.
Fore
