1:32 Roden GB 2008 Spad VII
North Carolina, United States
KitMaker: 604 posts
AeroScale: 600 posts
Posted: Sunday, March 08, 2009 - 12:24 PM UTC
OK, I have closed everything up. The cowl ring met the fuselage sides with no trouble. The lower nose panel also lined up. When I applied the upper cowl panels there was about a 1/8th inch gap in the middle
The upper pieces do line up with the cowl ring and the fuselage sides. Don't know why I have a gap. Plastic strip should fix the problem
RAGIII
Posted: Thursday, March 12, 2009 - 05:20 PM UTC
looking very sweet so far Rick .
West Virginia, United States
KitMaker: 1,121 posts
AeroScale: 1,063 posts
Posted: Friday, March 13, 2009 - 04:20 AM UTC
Rick,
I agree with everyone wholeheartedly. I especially like the painting you did on the interior. The wood grains look great.
KitMaker: 604 posts
Posted: Sunday, March 15, 2009 - 01:14 PM UTC
Rick,
Thanks for the compliments! I am juggling several builds at this time and MUST focus on a couple for Internet modeler that are way overdue! That being said this is not entirely backburnered as I work on it during drying periods for oils and sub assemblies of the other kits.
RAGIII
Posted: Sunday, March 15, 2009 - 02:02 PM UTC
KitMaker: 604 posts
Posted: Thursday, November 19, 2009 - 02:34 AM UTC
With Stephen's build of the Lafayette Escadrille version of this kit imminent, I thought I might take another look at my build. One of my last comments was that "I encountered no more difficulties with the cowling assembly". I must have been looking forward based on my test fitting as this turned out not to be true! Even with the ground away cylinders the engine covers did not fit! As far as I can see, one will be left with a gap that needs to be addressed. In my next post I will post a couple of new photos showing my solution, and a link to Internet Modeler showing Mark Flakes ultimate solution to this issue.
RAGIII
KitMaker: 604 posts
Posted: Thursday, November 26, 2009 - 01:06 AM UTC
Here are the pictures showing the gap in the assembled cowl panels. The gap measures 2mm at the front and 1mm at the rear. I used sheet styrene to fill, and will sand and fill with epoxy putty as needed.
Had one picture up then Windows did an auto update knocking me off line. came back added 2 more and had all red xs'. Back to the drawing board.
KitMaker: 604 posts
Posted: Thursday, November 26, 2009 - 01:40 AM UTC
KitMaker: 604 posts
Posted: Thursday, November 26, 2009 - 04:13 AM UTC
here is the link to Mark Flakes I.M. build showing how he handled the ill-fitting cowl parts.
Click here.P.S. Hopefully someone can fix whatever it is I do wrong with the links when I post them!
Texas, United States
KitMaker: 365 posts
AeroScale: 356 posts
Posted: Thursday, November 26, 2009 - 07:53 AM UTC
Rick,
The SPAD VII is coming along nicely.I'm on pins and needles waiting to see what's next. There's noway around it,I've got to have one of these little gems in the collection.
Reagrds,
Gregory Jouette
AKA Spads
Posted: Thursday, November 26, 2009 - 01:26 PM UTC
When every I see more of your progress Rick it always leads to better inspiration on my skills . You handled to fit issue very well indeed
Thank you for continuing with this build and sharing your progress !
cheers
Mendoza, Argentina
KitMaker: 222 posts
AeroScale: 219 posts
Posted: Friday, November 27, 2009 - 03:50 AM UTC
I like it, I can wait to see it finished!
By the way, somebody (Stephen?) knows if Roden has plans to release a Spad VII decorated with the large cockerel's head emblem of the Escadrille SPA 48 ?
Regards,
Claudio
I have always imagined that Paradise will be a kind of library.
Siempre imagine que el paraíso sería algún tipo de biblioteca.
Jorge Luis Borges
KitMaker: 604 posts
Posted: Friday, November 27, 2009 - 02:23 PM UTC
Thanks Greg, Terri and Claudio! We will see if my solution proves to work as well as Marks?
By the way, IIRC Larsa was working on one of these way back when I started. Larsa did you finish yours? Almost at the painting stage, just a few holes to drill
RAGIII
Mississippi, United States
KitMaker: 8 posts
AeroScale: 6 posts
Posted: Saturday, November 28, 2009 - 02:32 AM UTC
To digress a moment - How do you make those trunbuckles in 1/48 scale?
KitMaker: 604 posts
Posted: Saturday, November 28, 2009 - 03:12 PM UTC
Terri, I think this question is for you!
RAGIII
Posted: Tuesday, December 01, 2009 - 12:46 AM UTC
Hello glarba .
For making the turnbuckles and their attachment points . I did a small titorial in the dual Pfalz D.IIIa build . Just click on my profile and it's listed under feautres . Sorry , don't know how to add the link to it .
KitMaker: 604 posts
Posted: Thursday, December 03, 2009 - 12:11 PM UTC
Here is a question for the field. Anyone have the Part set for this kit? Considering the point in construction I have reached is there any good reason for me to consider purchasing the PE?
RAGIII
Posted: Friday, December 04, 2009 - 09:54 AM UTC
RAGIII
I may have this set to review in the near future and I'll give you a head's up!
Click here. ". . .The most important thing is to know why you build and then get the most that you can out of building." via D.D.
KitMaker: 604 posts
Posted: Sunday, December 06, 2009 - 01:56 PM UTC
RAGIII
Click here.
Thanks Stephen, I saw your review of the Eduard Sets and must say that the full set has quite a lot of exterior pieces that would be useful. I sure wish this had been available last year when I started this build.Would really have spruced up the interior!
RAGIII
Attica, Greece / Ελλάδα
KitMaker: 1,437 posts
AeroScale: 1,241 posts
Posted: Monday, December 07, 2009 - 01:19 AM UTC
KitMaker: 365 posts
Posted: Friday, December 11, 2009 - 10:19 AM UTC
Rick,
How's the SPAD VII progressing? Inquiring minds want to know,ok just being nosey but still....
Regards,
Gregory Jouette
KitMaker: 604 posts
Posted: Friday, December 11, 2009 - 02:46 PM UTC
Rick,
Regards,
Gregory Jouette
Thanks to both Nick and Gregory for the encouragement.... and subtle push
I have done the final filling and sanding. I would post a pic but it would look much the same as the last! By the way Gregory, I looked at every one of your builds on Hyperscale during the WW1 theme on "ThemePics". Very impressed by your work!
RAGIII
