Messerschmitt Bf-109 E-4 1/48 of Tamiya
hkopper
KitMaker: 529 posts
AeroScale: 340 posts
Posted: Sunday, June 07, 2009 - 06:24 AM UTC
Great progress Daniel ...as was mentioned before, the detail that the P.E. parts brought to the wheel well was impressive (worth the time and effort that was put in). Can't wait for further updates!
dcandal
KitMaker: 918 posts
AeroScale: 688 posts
Posted: Sunday, June 07, 2009 - 06:42 AM UTC
Steffen said
Hi Steffe, do you mean this,
I´m thinking on putting some metal foil there
do not forget to get rid of the pin marks towards the center of the wing from the gear leg mounts .....
dcandal
KitMaker: 918 posts
Posted: Sunday, June 07, 2009 - 06:44 AM UTC
Hi Terry,
Yes, it´s looks incomplete, but tehre aren´t PE for that place so I´m thinking in putting some metal foils there
dcandal
KitMaker: 918 posts
Posted: Sunday, June 07, 2009 - 06:45 AM UTC
Hi Chuck
Thanks for your comments. Yes, those details give a better and real view to the model. It takes a lot of work but I like to add this type of details to the models
dcandal
KitMaker: 918 posts
Posted: Sunday, June 07, 2009 - 06:47 AM UTC
Hi Hermann, thanks a lot for your comments, I´m glad you like this project, thanks to follow it
Posted: Sunday, June 07, 2009 - 07:02 AM UTC
Yes I meant these.
... I sanded one before completing the wings on my kit but had to fiddly remove it in the other (not a real problem though). Measure twice cut once
.. often run in those things myself
Hmm, seems am always complaining ... I know you are a very good modeller so I do not comment on your nice progress but only on some possible problems. In the end I just do not want you to make such a beautiful model and have it ruined by basic things ...
all the best
Steffen
all the best
Steffen
dcandal
KitMaker: 918 posts
Posted: Sunday, June 07, 2009 - 10:05 AM UTC
Hi Steffen,
I consider you a very good modeller. I think we are here to show what we know, but also, and more important to continuing learning, so any comments are welcome. I have in mind all of yours
dcandal
KitMaker: 918 posts
Posted: Tuesday, June 09, 2009 - 10:37 AM UTC
Then I had joint the fuselaje, and gave a grey paint to advice any mistake after sanded it,
dcandal
KitMaker: 918 posts
Posted: Tuesday, June 09, 2009 - 10:38 AM UTC
Here I´m preparing the horizontal stabilizer
Posted: Tuesday, June 09, 2009 - 07:44 PM UTC
Hi Daniel
very nice progress .. see I can say something positive before I grump
I just want to remind you, that you will have to restore the panel line between the fuselage halfs. the half shells overlap and make up a panel line on top and bottom aft of the cockpit, which should be a bit off center (forgot to which side) ... On my model I just used the kit panel line and engraved it with the TriTool "modelling scriber saw" (Hasegawa), which gives a cleaner line that scribing. Of course this is not like it looks in reality, but today it is en vogue to simulate it with engraved lines.
all the best
Steffen
all the best
Steffen
AirLedge
KitMaker: 292 posts
AeroScale: 265 posts
Posted: Friday, June 12, 2009 - 07:25 AM UTC
Hi Daniel,
Thanks for the advice on the trumpeter rivet tool.
The 109 is coming along nicely, can't wait to see it finished,
Mike.
Mike.
Emeritus
KitMaker: 2,845 posts
AeroScale: 1,564 posts
Posted: Friday, June 12, 2009 - 08:06 AM UTC
Really impressive progress you have going on there!
I was already about to mention the fuselage seam but Steffen got it first. Seems like you learn something new everyday, I wasn't aware the seam was off-center on the real thing.
Even though it's a bit inaccurate then, I prefer doing the seam by scraping the edges of the fuselage halves at about 45 decree angle prior to gluing them together to avoid any tricky, error-prone scribing later.
dcandal
KitMaker: 918 posts
Posted: Saturday, June 13, 2009 - 01:51 AM UTC
Hi Mike
Your welcome, I´m glad you like the progress
dcandal
KitMaker: 918 posts
Posted: Saturday, June 13, 2009 - 02:04 AM UTC
Hi Steffen and Eetu,
Thanks for your comments, it help me to improve my technics.
Perhaps it´s late for this model because I had joint it, but to have in mind for the next.
But let see if I understand what you mean. I know that the real planes are make with panels, each side of this panels are put up on others panels side and then they make the rivet. So this generate an unevenness between the panels, but I think it´s practically impossible to obtain this effect in a model kit, so I think I´m not understanding what you mean
Posted: Saturday, June 13, 2009 - 02:24 AM UTC
Hi Daniel
well, the rear fuselage is made up of these
These were made of two halfs, which meet at the top and the bottom. There they form a panel line which starts behind the pit and goes right to the rudder (analogue on the underside). The Bf 109 not only won the fighter competition becaus Willi was a brave Nazi but also because the 109 was easier and faster, read cheaper to produce than the He 100 ...
I remember that Lynn Ritger once posted some pix which clearly show this panel line, but I cannot find it now. Just have a look at some drawings ...
This is an F (but it is the same on the E) and was taken from 109 Lair and reworked to show my point
hope this makes things clearer
cheers
Steffen
cheers
Steffen
dcandal
KitMaker: 918 posts
Posted: Saturday, June 13, 2009 - 03:10 AM UTC
Ahhhhh, yes, now I understand what you mean, and yes, I have that in mind, here some photos I have of this,
Thanks againg steffen
dcandal
KitMaker: 918 posts
Posted: Saturday, June 13, 2009 - 03:18 AM UTC
Well, continuing with this model I had masked the cockpit to give a grey first hand of paint,
dcandal
KitMaker: 918 posts
Posted: Saturday, June 13, 2009 - 03:20 AM UTC
I had also masked the cockpit glass. For this I used the Eduard mask that come with the Big Ed,
Posted: Sunday, June 14, 2009 - 03:54 AM UTC
Excellent progress Dan !
dcandal
KitMaker: 918 posts
Posted: Sunday, June 14, 2009 - 11:56 AM UTC
Thanks Terri
dcandal
KitMaker: 918 posts
Posted: Monday, June 15, 2009 - 04:04 AM UTC
After this I gave a pre-shade to the panels,
dcandal
KitMaker: 918 posts
Posted: Monday, June 15, 2009 - 04:05 AM UTC
And when it was dry I gave a first hand with RLM 65,
hkopper
KitMaker: 529 posts
Posted: Tuesday, June 16, 2009 - 10:59 AM UTC
Excellent progress Daniel!!
dcandal
KitMaker: 918 posts
Posted: Tuesday, June 16, 2009 - 12:10 PM UTC
Thanks Hermann
dcandal
KitMaker: 918 posts
Posted: Wednesday, June 17, 2009 - 03:35 AM UTC
When the paint was dry I had masked the plane, for this I used tamiya mask and Uhu-Tac
