Paint...yes soon soon....long weekend coming
Well Stephen asked for a few comparison shots.....between my Wingnut & Roden kit....of course
Andso here is a few. I'm not knocking at either companies...both have plusses and both minuses. I will give my conclusion at the end. I'm not rivet/stich counting either....I will when I dig deeper seeing some of the anomilities.
starting at the front...
three offerings of radiator front grills, Wingnut...Mastercaster...Roden. The roden is very basic...the Wingnuts better bur not brilliant, Mastercasters Resin Viper replacement is much finer but even that could be inproved (it fits the WNW kit BTW...could end up modding mine yet)
The motor....here WNW shows some finer detail but on some of the ancillaries Roden actually beats it for detail. Now basically I'm presuming from my limited info that the viper was copied from the hisso so there is some big differences in the shape and size of the engines....the Roden cylinder bank is a good 3mm longer though the block from tail to front is the same....front of Roden casing to front of WNW gear housing. Correspondingly the fuselage is 3mm longer too, now isnt that strange?
Dash.... now here I am oddly divided....the thin coaming? around the pilots seat is much better represented in the WNW but the actual dash.....I think Roden steal...mine here has had extensive work thinning and drilling out all the instruments. For such a focal point in any A/C kit, WNW might have done a little more to show the valves and pipework, it was rather old style relief before I shaved it off.
Wings...now this is where WNW have completely stole the show.........there is some differences in detail though see the rigging/control wire point on the lower wing for instance.
Now.....a lot of the detail, wing joints, mounting bolts etc I have added myselfto Roden's wings and theres a few little details even WNW missed I have to add to theirs.
Rodens wings sizes are different to WNWs slightly, wider chordwise by a smidgin and the upper is wider spanwise than WNWs but the lower is narrower by a mil or so. Again I have no idea which is closer to true.
wheels and U/C.... here the difference is outstanding....detail wise and shape varies greatly
Wheels, Roden's on the right are a good 2.5mm larger.....Mastercasters in the centre match the WNW wheels pretty closely so I can only assume Rodens are OS but maybe there was variations...
well here the detail difference is just.....no comparison...the tails match up pretty spot on dimensionally but.....theres a noticeable difference in the angle of the inner edge of the elevators Rodensteeper leaving a wider gap than WNWs though both look right fitted to their relevant fuselages.
Well I did take other shots...but light, shakes etc make them unusable. but cowlings coaming etc all have much better refined detail on WNWs offering, the exhausts however...the fronts are beautiful but the tails are quite poor to my eye. And little things like the control column seem better on Rodens but point for point without checking for accuracy...WNW looks much finer, and builds easily into a nice finished kit OOB
My tuppence worth
Keith.
