Hi Arseny
Neat! I used to do something very along those lines about 15 years ago by spraying Halford thick aerosol plastic primer - I'd forgotten all about it, so thanks for reminding me!
Using the "reverse" technique also works very well, i.e. mask the ribs with Dymo or another fairly robust tape and sand gently between them. It gives a very nice subtle effect that is especially useful on master parts for casting, because it can't be damaged when you remove them from the RTV mould.
I've been out most of the last few days so there's been little chance to do anything to the Dora, but the last of the decals are on and have had a chance to really dry out:
I haven't applied the stencil markings where the aircraft was repainted, and I've cut the wing-walks short for the same reason (I'll do a slight overspray to soften the "cut-offs"). I've no idea whether the real aircraft was that way - to be honest, Eduard's stencils don't actually match the few shots I've got of Dortenmann's aircraft anyway, so it's all artistic licence.
The spinner spiral decal for Dortenmann's colour scheme has defeated me! Although it would go on, the resulting spiral was nowhere near as tight as either Eduard or Jerry Crandall show in their profiles, so I scrapped it. I may try one of the other spirals, but I think it'll be easier to simply paint it.
I should get a decent day at the workbench tomorrow, so I'll respray the RLM 04 and the fuselage cross and try to get moving again generally.
