Brad – Excellent behind the scene look, you make all this look almost easy and very, very good, all at the same time.
Thanks for sharing your hard work!
WNW 2009 -10 Alb. D.Va Brad C
OEFFAG_153
Posted: Friday, April 30, 2010 - 12:33 AM UTC
edoardo
KitMaker: 642 posts
AeroScale: 382 posts
Posted: Friday, April 30, 2010 - 01:45 AM UTC
Hey Brad!
your work is outstanding! and the tutorial you made is inspiring! I have saved your pictures as future reference!
ciao
Edo
ciao
Edo
Mgunns
Posted: Friday, April 30, 2010 - 02:45 AM UTC
Great job on the wood grain and the diamonds. The tutorial is very helpful and I will be trying your techniques on the DII I am building now as I am at the stage of applying the Yellow. Your build is truly outstanding.
Best
mark
Posted: Friday, April 30, 2010 - 02:51 AM UTC
Well done on the masking , this is not an easy task . your wood grainning just keeps getting better and better and 32 scale is a perfect canves for your skill to shine
Looking forward to your next up-date Brad
gajouette
KitMaker: 365 posts
AeroScale: 356 posts
Posted: Friday, April 30, 2010 - 03:25 AM UTC
Brad,
Wow I just can't get passed your wood graining which is always excellent.But this latest effort appears darn near real.Absolutely stunning artistry my friend,and I don't mean just the wood graining but the total package.Construction,fit,details,and paint all outstanding.
I do have one question though.The two pipes or hoses that drape over the oil tank,what purpose do they serve?I'm looking forward to your next update.Keep up the great work.
Regards,
Gregory Jouette
Regards,
Gregory Jouette
Posted: Friday, April 30, 2010 - 03:31 AM UTC
The two pipes going over the tank are empty shell shoots and exit from the under side of the aircraft . Keith has done this on his buiild . Sorry Brad for the hijacking of the answer . I'll go to my room now
Kornbeef
KitMaker: 1,667 posts
AeroScale: 1,551 posts
Posted: Friday, April 30, 2010 - 05:04 AM UTC
Ref the two pipes
I thought they were drain offs for the gun synch mechanisms, they dont seem to appear on all A/C though.
Keith
Keith
Posted: Friday, April 30, 2010 - 05:15 AM UTC
Now that makes more sense Keith, for some reason empty shell shoot was in my head .Ref the two pipes
Keith
-RLWP-
KitMaker: 33 posts
AeroScale: 32 posts
Posted: Friday, April 30, 2010 - 07:46 AM UTC
They certainly are the empty shell chutes. The Maxim 08/15 pulls a loaded bullet from the belt at the top, lowers it down, pushes it into the breech and fires it, then pulls the empty shell out of the breech lowers it down and pushes it out the front of the casing under the barrel.
The tubes take the spent cases and drop them out the bottom of the aeroplane.
On a Fokker DR.I they sometimes fitted a little metal shield instead to carry the cases away out to the side of the aeroplane.
Guess who's just working on a pair of Maxims...
Richard
Richard
CaptainA
Posted: Friday, April 30, 2010 - 10:16 AM UTC
Peanut butter and chocolate, beer and brats, bread and butter, Brad and Albatros. Perfect combinations.
Boy, did I call that one, or what?
I considered trying this scheme, but dismissed it as being to difficult. Now I can't try it because it would never be as beautiful as what you have accomplished Brad. This is absolutely stunning.
There is a chute that leads up to the Maxims that is the ammo feed. Then there is a chute that leads out of the opposite side, Which I thought was the collection bin for the spent casings. (A valuable comodity in war time.) Those tubes are too small to collect casings, and seemingly would cause the Maxims to be prone to jaming. I thought they were some type of a lubricant drainage tube. I have no documentation to prove this, it is just a personal opinion. I checked my meeger references, and found nothing.
badwolf
KitMaker: 79 posts
AeroScale: 75 posts
Posted: Friday, April 30, 2010 - 10:41 AM UTC
Sorry bit slow with this reply,
i have been practising doing the woodgrain effect on a cheap smer kit, which i can strip the paint down and have another go, how you are doing yours, is how i am trying to do mine, but just as i thought i was getting somewhere, i had to see your finish, and you are on another level, its like moving the goal post, its simply stunning!
-RLWP-
KitMaker: 33 posts
AeroScale: 32 posts
Posted: Friday, April 30, 2010 - 11:32 AM UTC
CaptainA, the chute on the left side of the machine gun takes the empty ammunition belt down into a storage box. So belt goes through the gun right to left, bullet cases go through the gun top to bottom and get ejected out the front under the barrel.
I guess the Albatros chutes are there to stop you ending up ankle deep in hot, smoking, empty shell cases. Fokker pilots got them falling back towards their face. It's dangerous stuff this war business
Richard
Richard
Kornbeef
Posted: Friday, April 30, 2010 - 01:36 PM UTC
well you learn something new every day
CaptainA
Posted: Friday, April 30, 2010 - 11:42 PM UTC
I guess the Albatros chutes are there to stop you ending up ankle deep in hot, smoking, empty shell cases. Fokker pilots got them falling back towards their face. It's dangerous stuff this war business![]()
Richard
I was a tanker. Spent time an a tank with a 105mm Main Gun. I know all about being ankle deep in hot, smokin shells. Those 105s pile up real fast.
Posted: Saturday, May 01, 2010 - 02:46 AM UTC
I was correct the first time , but do to being confused which happens very often , some times more then once a day !
-RLWP-
KitMaker: 33 posts
AeroScale: 32 posts
Posted: Saturday, May 01, 2010 - 04:27 AM UTC
Hi Carl, and thanks for the welcome.
I've got another build on the go at the moment, so I'll pass on this one. When I further through I'll start a thread on my DR.I
Richard
Richard
Posted: Saturday, May 01, 2010 - 06:08 AM UTC
Ladies and Gents,
Richard and I have flown over the salient on many occassions. He's one of the few fellows who finished his Battle Axe Fokker D.VII (also in Jasta 7 markings). Always a pleasure to have you here old man. Model On!
-RLWP-
KitMaker: 33 posts
AeroScale: 32 posts
Posted: Saturday, May 01, 2010 - 07:11 AM UTC
Ladies and Gents,
Steady Old Man, the scars, remember?
Thanks Stephen
Richard
BradCancian
KitMaker: 285 posts
AeroScale: 281 posts
Posted: Sunday, May 02, 2010 - 03:21 PM UTC
Well as expected, it didn't take me too long to get the rest of this build finished. So here she is:
With regards to the kit itself - I have never built a Wingnuts kit before, but I can certainly say that this is a stunning, comprehensive and well engineered model straight out of the box. There are some minor fit issues (i.e. getting all of those interior goodies in, for example), but these are very minor issues. The only other issue is the slightly bowed upper wing (which I may have "accidentally" straightened in some hot water). The decals are also excellent and respond well to decal setting solutions. The kit is indeed a real joy to build, and could easily be built by those with any level of experience. One nice extra would have been some lozenge decals, but I am sure these will come in future issues of the kit. I also would expect after market decal and detail set makers to start coming out with some goodies for this kit real soon.
Anyways, thanks to all for your very encouraging words throughout this build.. I am not used to having something this big in my little display case.... I think I will try something in 1:72 next...!
BC
BC
Posted: Sunday, May 02, 2010 - 04:32 PM UTC
Most Impressive Brad! You never disappoint with your builds. I imagine youe will be setting your sights on the new Roden 1:48 DH 9? You do know its been released. . .
Posted: Sunday, May 02, 2010 - 08:37 PM UTC
Hi Brad
It's absolutely gorgeous! Let's get it onto the Frontpage asap! Just send pics and text to Jean-Luc or me and we'll do the rest.
MrMox
KitMaker: 3,377 posts
AeroScale: 115 posts
Posted: Sunday, May 02, 2010 - 09:45 PM UTC
Beautiful build - sharp and clear, you really have raised the bar!
Cheers/Jan
Cheers/Jan
Mgunns
Posted: Monday, May 03, 2010 - 02:10 AM UTC
Best
Posted: Monday, May 03, 2010 - 02:17 AM UTC
Beautifully done Brad . The engine looks super with the cowlings off
