WNW GB 2009- 10 SE.5a - Des
Arizona, United States
Posted: Saturday, May 15, 2010 - 02:45 AM UTC
Hi Des:
That engine is a masterpiece in miniature. A delight to look at with the subtle shading and washes.
Best
We few, we happy few........
New South Wales, Australia
KitMaker: 366 posts
AeroScale: 309 posts
Posted: Sunday, May 16, 2010 - 11:14 AM UTC
Thanks for all the nice comments.
Here are three photos of the completed Hisso engine. I replaced all the plastic pipes from the bottom of the engine and used copper wire and brass tube. Once the engine is installed in the fuselage I will add fuel lines, throttle linkages and electrical wiring. I like building my models with ä "straight from the factory" look so I will not be weathering the engine.
Des.
A full build log of this engine can be found on my website;
Check my site for 1:32 scale WW1 aircraft model build logs, build techniques, how to make turnbuckles and eyelets plus much more, plenty of photos of my finished models
Milano, Italy
KitMaker: 642 posts
AeroScale: 382 posts
Posted: Sunday, May 16, 2010 - 09:49 PM UTC
It is a real beauty, Des!
The "Black" on the cylinders is a little too dark to me, but maybe it is just a problem of the pics or on my PC.
I'll check yor site for more pics!
great work!
ciao
Edo
Posted: Monday, May 17, 2010 - 02:37 AM UTC
Go Des Go !
Posted: Monday, May 17, 2010 - 05:42 AM UTC
KitMaker: 366 posts
Posted: Thursday, May 20, 2010 - 01:41 AM UTC
The first photo shows the Pheon resin replacement fin which I have fitted. It has very nice crisp detail as does the rudder which comes with the fin. I removed the original fin with a razor saw then fixed the Pheon fin with CA.
The second photo shows the radiator, instead of using brass coloured paint I decided to fix very thin brass sheet, it was fixed to the radiator with CA. The new filler pipe was turned from a piece of 2.5mm brazing rod, also fixed with CA.
Des.
Posted: Thursday, May 20, 2010 - 05:49 AM UTC
Hi Des:
Radiator looks good witht he real brass. Somehow gold paint just doesn't do it. Are you going to coat it with something to prevent it from tarnishing? Looking forward to seeing how this will look with that great engine displayed, the radiator will only enhance the appearance.
Best
#439
Washington, United States
KitMaker: 4,950 posts
AeroScale: 3,192 posts
Posted: Thursday, May 20, 2010 - 06:41 AM UTC
Really nice!
Hanger Queens in Waiting:
Monogram 1/72 F8F-1
Academy 1/72 F-84E
KitMaker: 366 posts
Posted: Tuesday, May 25, 2010 - 12:20 AM UTC
Another progress up-date of the 5a.
Painting is just about completed, decals are fitted and the entire plane has been clear coated. The decals are from Pheon Models, very thin, easy to manage, adhere well and conform to any shape quite readily. The scheme is;
F5910 41 Sqn, Conteville, France. August 1918. Capt. W. G. Claxton.
Photo 2 and 3 show the engine and radiator fitted, I still need to add fuel lines, throttle linkages and electrical wiring from the firewall to the engine.
Des.
A full build log can be found on my website.
Posted: Tuesday, May 25, 2010 - 02:49 AM UTC
Hi Des:
The radiator really enhances the outstanding engine work. The rest of the plane looks good as well. I like the color, just a hint of green. What did you use?
Take care
Posted: Tuesday, May 25, 2010 - 03:31 AM UTC
Hi Des:
Take care
Will second that , nicely done so far Des . Looking forward to seeing the rest of the details added to the engine .
KitMaker: 366 posts
Posted: Tuesday, May 25, 2010 - 10:44 AM UTC
Thanks Terri for your nice words, they are much appreciated.
Mark..thank you also for your kind comments. The PC10 is a mixture of Humbrol 155 + about 10% 0f Humbrol 113, once dry I then applied two coats of Humbrol Matt Cote (absolutely brilliant stuff)thinned with about 60% enamel thinners.
Because the original PC10 colour was a variety of shades I wanted a colour a little different to my other PC10 painted models, side by side there is not a great deal of difference but enogh to make them stand apart.
Des.
http://www.ww1aircraftmodels.com Check my site for 1:32 scale WW1 aircraft model build logs, build techniques, how to make turnbuckles and eyelets plus much more, plenty of photos of my finished models
KitMaker: 366 posts
Posted: Wednesday, May 26, 2010 - 12:49 AM UTC
My apologies to everyone, I goofed......
With the particular scheme I chose, the aircraft should NOT have the head rest and fairing. When applying the decals I must have checked Pheon Models excellent decal instruction sheet a dozen times but for some unknown reason I didn't notice the lack of a head rest, boy, talk about not seeing the forest for the trees......
Anyhow, it can't be changed so Captain Claxton now has a head rest.
I will now continue with my not so accurate 5a build.
Des.
KitMaker: 118 posts
AeroScale: 89 posts
Posted: Wednesday, May 26, 2010 - 01:05 AM UTC
Great Build................
Posted: Wednesday, May 26, 2010 - 02:06 AM UTC
With the particular scheme I chose, the aircraft should NOT have the head rest and fairing. Anyhow, it can't be changed so Captain Claxton now has a head resr.
Des.
Hi Des:
I know some where there is a picture of that self same a/c with a headrest on it, I just can't place it. I had read that somewhere a factory spec'd headrest and fairing was installed at a forward air field. The photographer's were notified, however never showed up; so the pilot went out and completed his mission. The nature of the installation has since been lost to history, until this very moment.
Either way, it is a great build.
Best
KitMaker: 1,667 posts
AeroScale: 1,551 posts
Posted: Wednesday, May 26, 2010 - 04:25 AM UTC
ref above....never say never...just cos It didnt have one when the pics were taken doenst mean it never did before or after...that apart, WONDERFUL build
Keith
KitMaker: 366 posts
Posted: Thursday, May 27, 2010 - 01:35 AM UTC
The first photo shows the starting magneto winding handle which I made. Also the Aldis sight and the windscreen have been fitted.
Photo No.2 shows the Aldis sight, I cut off both ends and fitted the same length 2mm brass tube, I used CA to fix the tube in place. The sight is painted with Humbrol Satin Black. This photo also shows the windscreen very well, the prop is only a temporary fit.
Brass and copper does tarnish over time so I have coated all the brass and copper bits with clear finger nail polish, it is crystal clear, dries fast and very hard.
Thanks for all the kind comments, makes me feel better about the head rest.
Des.
KitMaker: 366 posts
Posted: Monday, June 07, 2010 - 10:46 PM UTC
I have finally finished the SE.5a, my 4th model in the WNW GB. It was a pleasure building this model, I encountered no major problems throughout the entire build, Wingnuts have to be congratulated for producing such a wonderful kit. The addition of the Brian Fawcett fin and rudder set plus Pheon Models decals certainly improves the appearance of the overall model.
I hope the following photos do justice for the model.
Des.
KitMaker: 366 posts
Posted: Monday, June 07, 2010 - 10:49 PM UTC
KitMaker: 118 posts
AeroScale: 89 posts
Posted: Tuesday, June 08, 2010 - 12:18 AM UTC
West Virginia, United States
KitMaker: 1,121 posts
AeroScale: 1,063 posts
Posted: Tuesday, June 08, 2010 - 12:28 AM UTC
Milano, Italy
KitMaker: 642 posts
Posted: Tuesday, June 08, 2010 - 12:39 AM UTC
Des!
A real beauty!
Did you happen to have build also the Roden kit? How is it?
ciao
Edo
Aarhus, Denmark
KitMaker: 3,377 posts
AeroScale: 115 posts
Posted: Tuesday, June 08, 2010 - 12:40 AM UTC
Beautiful build - the addition of brassparts works very well, and really lifts the details.
I have one in transit from WNW - can hardly wait
Cheers/Jan
It“s happy days for modellers...
Posted: Tuesday, June 08, 2010 - 01:01 AM UTC
Very , very well done Des !
KitMaker: 366 posts
Thanks guys for your kind words, much appreciated.
Edo.. I built the Roden SE.5a last year, it is also a very good kit, it lacks some of the detail which Wingnuts has put into their kit but it still makes up to be a nice model.
Des.
