A clear advantage of the Dragon kit in comparison to the ED is the width of the rear fuselage (behind the cockpit section). The Eduard kit is much too shallow (even worse than the Fujimi), wouldn´t work with a real plane. The "upper curve" from the fuselage sides to the top is a bit sharp, this must be sanded - an item that is more confidental with the Fujimi and the ED kit. The cross-section of this part of the plane as a close relation to that of the 109.
The nose looks better than the ED which appears to be too long (Fujimi`s is too short).
As on the ED kit the kink on the trailing edge of the main wing is missing (but it appears correctly on the Fujimi). BUT I have to consider that ED might have changed the moulds. I saw a G-4 in a show which had the kink (my two kits of early production runs don´t have them).
Can`t tell on the engines/nacelles now.
Andreas
I am sorry but I do not understand at all what you are saying: You say the Dragon is better in width, then that the Eduard is too shallow, which implies a vertical issue: The two dimensions are at 90° to each other!
Also you seem to imply the Dragon 110 spine is too sharp, pointing out that the real-life similitude should be close in appearance to a Me-109... Yet the real-life Me-109 had an extremely sharp spine! I measured the Hasegawa 1/48th Me-109 spine, at frame 4, to be 82 mm wider(!!!!), at 100 mm profile depth from the spine's top, than the unrestored Ottawa National Air Museum's Me-109F: 254 mm actual width vs 336 mm Hasegawa...
That is well over a 3.2 inches error in a very small and narrow dimension... Only the upcoming Zvezda Me-109F kit has ever depicted this correctly among all the Me-109 kits...
So I doubt the Dragon spine could be too sharp if it should in fact match a real Me-109...
Interesting and very useful point about the 110 trailing edge kink...
The biggest problem by far with the Eduard kit, that I think Dragon seems to have fixed, is that the plan view of the real canopy "swells" wider in the middle very slightly, while the Eduard, it seems to me like all other 110 kits, has the canopy sides in plan view as two near-paralell straight lines! This "swelling" is especially noticeable on the top corner edge of the canopy...
However, this not just a canopy issue, but a fuselage top half cross-section "swelling" issue as well...
Quite an enormous problem I would think!
This is only an impression I got from small photos of the Dragon kit clear part, but the "swell" appears to be there in the real aircraft, making the canopy's mid-section look wider (especially at the top edge) compared, it seems to me, to all Me-110 kits previous to the Dragon (In 1/32 I think Dragon got the "swelling" correct also)...:
http://www.warbirdphotographs.com/LCBW7/Me110-19bf+.jpg It would be nice if someone with the 1/48th Dragon kit would confirm my impression of this point (or of the wrongness or not of the Eduard kit's canopy plan-view "swelling" if I am mistaken), and clarify what I did not understand from the quoted post above...
Gaston
