OFFICIAL: Battle of Midway, 1942 Campaign
MichaelSatin
KitMaker: 3,909 posts
AeroScale: 2,904 posts
Posted: Sunday, November 20, 2011 - 02:10 AM UTC
Paint question: The instructions call for the wheel wells to be painted Tamiya X-13, Metallic Blue. Does that seem correct? I'm doing an aircraft from the Akagi Aircraft Carrier Fighter Group.
Mike
Mike,
The years have caused a slight revision to the color (in their 1/32 A6M2 Tamiya recommends a mix of 3 X-13 blue to 1 X-25 clear green) but in essence, this is the color.
I doubt if anyone here will jump on you too hard if you just use the Metallic Blue from the bottle, but it probably should be bit more green.
Hope this helps!
Michael
On the bench:
KitMaker: 3,770 posts
AeroScale: 201 posts
Posted: Wednesday, November 23, 2011 - 12:40 PM UTC
Thanks Michael. Seems most everyone in town is out of the "Clear Green." I did get the Metallic Blue though.
Maybe I'll play with adding a touch of another green? We'll see.
Pics this weekend, but the cockpit is done, fuselage halves together, wings attached. Ran into a problem with the engine and cowling. Instructions show to put the cowling together first, then add the "engine." Uhh...no. Cowling is puttied and painted...and I really don't want to cut it, so I may jury-rig the engine. MTF!
Mike
Edit: Yellow and Blue make Green, right? Hehehehe...they have Clear Yellow and Clear Blue. Mmmmm....
Ontario, Canada
KitMaker: 270 posts
AeroScale: 264 posts
Posted: Thursday, December 01, 2011 - 01:00 PM UTC
And the little Academy Wildcat is done, as LtCmdr Thach's aircraft in the initial engagements of Midway. This aircraft was damaged and written off during the battle.
Academy F4F-4 Wildcat 1/72 by
mawz_models, on Flickr
Posted: Friday, December 09, 2011 - 02:19 AM UTC
Update, yay!
Leveling:
Primed:
Hope to break out the new AB tonight or this weekend.
Mike
Wisconsin, United States
KitMaker: 1,917 posts
AeroScale: 563 posts
Posted: Friday, December 09, 2011 - 03:09 AM UTC
Adam, excellent little Wildcat there. Really clean, even at this small scale. She's a beaut!
Mike, have fun with the new airbrush!
-Sean H.
edit: Adam, it looks like you'll have to fix that antenna though.
Current: model railroad layout
Stalled a while ago:
. 1950's Chrome, WW II Twins
Last completed: Police Car
Ontario, Canada
KitMaker: 270 posts
Posted: Friday, December 09, 2011 - 06:10 AM UTC
-Sean H.
Thanks, and the Antenna is actually on correctly, it's supposed to lean forward like that to clear the canopy and still get enough length on the wire.
Posted: Friday, December 09, 2011 - 06:23 AM UTC
-Sean H.
Well, I learn something new every day!
thanks again!
-Sean H.
MichaelSatin
Posted: Monday, December 12, 2011 - 08:16 AM UTC
Excellent work everyone! Now that the photo section is back up, don't forget to post images of your finished work in the
campaign gallery!
Michael
On the bench:
Hawaii, United States
KitMaker: 43 posts
AeroScale: 15 posts
Posted: Thursday, December 22, 2011 - 06:26 PM UTC
MichaelSatin
Posted: Friday, December 23, 2011 - 06:10 AM UTC
Tom,
Good choice! I know a couple of other guys here have built it, you might want to look at their threads for some small issues they found.
Michael
On the bench:
KitMaker: 43 posts
AeroScale: 15 posts
Posted: Friday, December 23, 2011 - 08:11 AM UTC
One step ahead of you, been looking at the Vals already completed and have been very impressed with what I've seen.
Just finishing up the office with a little help from my friends at Eduard:
KitMaker: 43 posts
AeroScale: 15 posts
Posted: Sunday, December 25, 2011 - 08:16 AM UTC
In proress shots: Getting ready for some priming and paint. Wing joins have been filled and sanded, as have the surprisingly troublesome wheel spats and engine cowl. I had acquired the True Details wheel set for the Val, but on inspection discovered that they are too narrow for the kit mounting pins, so they'll move into the spares box and I'll use the kit items instead. On assembling the dive brakes, I discovered to my horror that I was missing one part A2, so for now, until I get a replacement from Hasegawa (not being able enough to produce one myself), it will do without on center brace on the port side.
KitMaker: 43 posts
AeroScale: 15 posts
Posted: Sunday, January 22, 2012 - 10:03 AM UTC
MichaelSatin
Posted: Sunday, January 22, 2012 - 11:14 AM UTC
Great work Tom! Thanks for sharing it with us!
Michael
On the bench:
Slovakia
KitMaker: 825 posts
AeroScale: 476 posts
Posted: Tuesday, January 31, 2012 - 09:14 AM UTC
Wow, a lot of progress done since I was here last time.
Adam, the Wildcat is lovely .clean and simple build, wich I had more kits like that in the stash.
Tom, congratulation on the fine Val. You mastered all the problem spots of the Hasegawa kit with ease.
Texas, United States
KitMaker: 5,854 posts
AeroScale: 372 posts
Posted: Wednesday, February 29, 2012 - 09:21 AM UTC
Alright, I've had to drop a lot of campaigns due to real life circumstances, but I'm hoping to be able to complete a few including this one. I will be starting on my kit next week, and with some luck I can finish without the need for an extension. I'll get photos posted as soon as possible, looking forward to this one
MichaelSatin
Posted: Thursday, March 15, 2012 - 12:36 PM UTC
Great work so far everyone! Just out of curiosity, is anyone planning to build the star of the show (the SBD)?
Michael
On the bench:
KitMaker: 221 posts
AeroScale: 28 posts
Posted: Thursday, March 15, 2012 - 06:09 PM UTC
Hey Michael, Everyone, Nice builds going on here.
I figured to build the AM Vindicator but I have to move my kit stash this weekend and I have 2 AM SBDs up there. Have to see if they fit the time frame.
After dealing with some serious Real Life and having a motherboard failure a few weeks back I'm well overdue to scrape some plastic!
Charlie
Vice Commander - AmVets Post 182
KitMaker: 1,596 posts
AeroScale: 1,275 posts
Posted: Thursday, March 15, 2012 - 06:30 PM UTC
On the Polish modeling forum we have a similar group build. You can take a look how these guys are going:
Here are workbenches and
Here are the galleries (actually one gallery so far but should be filled up to the end of project).
MichaelSatin
Posted: Saturday, March 17, 2012 - 01:19 PM UTC
Nice site Michal, some great work going on there too!
I have the week off and, though I should be concentrating on some builds for other campaigns (since I have the F2A done here), I am sorely tempted to get this classic out:
I can't believe I've had this since its pre-release (Dec. 2000!) and haven't built even one of them (though I have build a couple of straight Acc Min SBDs). This could be the moment! I just got Craig Symonds' "Battle of Midway" for my birthday and my interest is re-aroused. We'll see...
Michael
On the bench:
MichaelSatin
Posted: Thursday, March 22, 2012 - 10:53 AM UTC
As promised, some progress on the Acc. Min. 1/48 SBD:
As I mentioned, this was a special boxing with parts to do late SBD-3s with the twin gun mount or SBD-4s with the later prop. It takes a bit of SBD knowledge to use the right parts, but they're all there including the un-noted later fuselage halves with the side doors for the twin guns.
Still without a doubt the best 1/48 Dauntlesses out there!
Michael
On the bench:
MichaelSatin
Posted: Sunday, March 25, 2012 - 09:29 AM UTC
And here's where I've gotten to before I have to go back to work. Sigh, progress will slow down a bit now.
Some "modeling skill required" around the wing roots and rear wing/fuselage joint, but no surprises having built the kit before.
Michael
On the bench:
Illinois, United States
KitMaker: 22 posts
AeroScale: 19 posts
Posted: Tuesday, April 17, 2012 - 07:18 AM UTC
I am going to be cutting this one close, I am in the middle east working and there is almost no odeling here! I have to improvise on my PBY!
MichaelSatin
Posted: Tuesday, May 15, 2012 - 02:11 AM UTC
Just a bit over three weeks to go everyone. How are you all doing?
Michael
On the bench:
Posted: Tuesday, May 15, 2012 - 03:57 AM UTC
Excellent work everyone! Now that the photo section is back up, don't forget to post images of your finished work in the campaign gallery!
Michael
I looked back at the gallery. It's really cool to see this collection of aircraft from both sides of the battle. One little moment in time-- the early-war paint schemes. All very cool.
-Sean.
