In the mid 1920's, the industrialist Henry Ford contemplated the mass production of a light aircraft intended for personal flying use. Ford was envisioning the flying "Model T", an aircraft to be supplied to and made attainable by populations.
I suppose that in a business sense, the idea of the masses purchasing and flying their own little airplanes made perfect sense. However, I'm fairly happy the project was cancelled after three prototypes. The sky's just not big enough for millions of little zippers flashing back and forth. Can you imagine the regulatory infringements that would beset us if such a plan were fulfilled.
Annyway, I plan to build one from the 1/48 Williams Brothers kit. Here are some photos of what's in the box:
Only a Single Sprue of Parts
A decal sheet that appears to be quite good. It allows to build three options. The original prototype with logos and no numbers, 268 as it appeared in 1927, and 268 as it appears today following restoration:
There are also instructions with good written information, a simplistic construction diagram, and a fine three-view:
I'm going to target the Ford Flivver as it appeared originally in 1927. That means a wood grain prop with copper cladding, original 268 numbers, and the short span ailerons. This is also the most well known version, thanks to the replica builders of the world.
