Thanks guys
@ Sean - I got a few pieces initially from a friend (where I got the idea), and then searched the internet and found a dental supply place in Colorado that had some. The size to get is .010 X .020, and unfortunately it seems to have been mostly discontinued in favor of thicker SS flat wire for ortho purposes. It's also not cheap, but you can get 20 pieces which should last for at least 5 or 6 models
@ Damien, no I put it back up, but I still need to address the issue that caused it to fall in the first place
@ Bob, you should be able to find another kit for $10 at a show or elsewhere, so that you can finish your build. I'm glad I'm finally getting this one done, as it should add some nice color to the display case
@ Sebastian - Gator Grip Glue is an acrylic white glue. See
here I know that A2Zee carries it for at least one EU distributor.
@ Jon - the only hard part of the kit is getting the upper wing together and getting rid of the step on the bottom. Once that is done, it's a great kit that fits well and is (obviously) very tough - I highly recommend it!
I think that is everyone, if I missed a question, please let me know!
Ok, made some more progress now that I've finished up another project. Added the rigging to the tailplane, rebuilt the aerial mast on the vertical stab, added the aerial mast to the upperwing, and took the big step of getting the engine together and attached to the fuselage! On the home stretch now
(prop is just lightly stuck on for photo op):
Still have to paint/decal the prop, add the aerial wire (and the one into the fuselage), paint the formation lights, and add one more piece of the exhaust, as well as the windscreen.
Thanks for looking, comments/questions welcome as always!
Doug
