You have to get a photo taken from an angle as close to 90° to what you want to guesstimate, in the case of dihedral, as close to directly in front or behind at datum level. There is no point in looking at Gaston's photo as it is taken from well above the datum and to the side. As the wing LE and TE on the Il-2 are not straight, any difference in angle above or below horizontal brings this plan view kink into play and makes it impossible to gauge dihedral by looking at the LE or TE.
This photo from the Squadron In Action, taken from behind but slightly above the datum is better for seeing the dihedral change on the top surface. It is low contrast, but if you place a straightedge on the top surfaces of each side of the centre section and extending to the tip, you will see the slight dihedral.
