More adventures in modelling as we return to the Kitten.
First the lovely little instrument panel. Take a good look...
And the seat in place in the cockpit. Say goodbye...
Because now the lid goes on and lookng inside becomes very difficult.
The fit is pretty good on this side, but on the other side I had to insert shims under the upper fuselage and at the joint behind the nose. The nose joint was more than 1mm wide. It took a lot of filling. I was so discouraged that I didn't take a picture before I slathered the Mr. Surfacer over it all.
Moving on, we come to the wings. And more fit issues.
The wings and the centre section are supposed to be the same chord. None of the pieces match. Since I didn't want to mess around with that sharp trailing edge, I got that lined up and left the excess at the leading edge, which is thick enough to withstand the sanding back I'm going to need to do. The wingtip ailerons are less than the size of a fingernail, and about as thick. Getting them drilled and pinned was an adventre, and as if that wasn't enough, they had bubbles at their corners. I sanded them to a straight edge and superglued in tiny triangles of scrap plastic which I sanded back to the proper airfoil shape after the glue cured.
Once again my fathful hobby knife serves for scale.
This build is definitely shaping up to be an exercise in "some modelling skills required".
