I added the dive flaps, and engine cowling prior to the glossing. The dive flaps really came out a lot better then I thought they would.
My brother had the Accurate Miniature's SBD-3 decal sheet, and offered it to me, since I was just more then a little concerned with the thickness of the Hasegawa decals. I opted to go with the basic AM decals.
I started decaling on the lower wings with the AM decals. They went on ok, but were super glossy, and were a real bear to get to conform to the panel lines, let alone the wing vents. They also started to crack from what I assumed was drying out due to old age. So I switched back to the Hasegawa decals. Nothing I used or did got the AM decals to really settle into those wing vents. So after they completely dried, I cut them, then applied a ton of Micro Sol, and when dry, touched up with either white or sea blue Tamiya acrylic paint.
The Hasegawa decals were a very pleasant surprise. Went on with a Matt finish, conformed to every panel line, and with Micro Sol actually settled into the upper wing vents.
I let the decals dry for a full day, then re-glossed with Glosscoat. 24 hours later I applied Flory Dark wash. I wasn't happy with the results. Just too much wiped off due to the gloss finish. So after I apply a Matt coat with Dullcoat, I'll apply the Dark wash again to the lower surfaces, and some light wash to the upper surfaces.
The overall finish looka a little too dark right now due to the gloss finish, but should lighten up once the matt coat is applied.
I had a accident when the Dauntless slipped out of my hand and landed on the main antenna mask, and snapped in half !! I re-glued it. Next will be a lite sanding, then primer and repaint. Should be good as new. Also the fuselage access door needs quite a bit of interior green touch up.
Thanks for stopping by and having a look.
