Been working on the weathering of the Widow, and as my usual practice I like the weathering effect to be what my Brother has termed: Used but not Abused. It really does fit for most USA WWII aircraft.
I sealed the decals with several coats of Pledge. Tested out a brownish enamel pin wash but just didn't like it as it didn't contrast with the Black at all, so I decided to use Flory's acrylic light sludge wash mixed with some of his dark sludge wash. The 1st application was just over all the recessed panel lines, when dry the excess was removed with a moist towel and Qtip. Then a few coats of the light/Dark, then just the light, trying to get an uneven faded finish on all the surfaces that receive sunlight. Unfortunately, no matter how I tried, these acrylic washes just don't do a good job with the blotchy effect I wanted. The original fading was done with an air brush, and I think from here on in, I'll do it that way.
I sealed the acrylic washes in Testors Dullcoat, so that I could see how the finish really looked. Then I applied a few coats of various earth colors thinned to the consistency of India Ink. Heavier applications of dirt were applied over the decals. Then a final coat of Dullcoat.
What's left is the paint chipping, and some staining. Never of which will be done to any great extent.
Here's a few pictures of the Widow now.
After carefully looking at the pictures, I was rather disappointed in the thickness of the stars and bars decals, while the lettering looks more painted on.
Also, I used Terry Deans weight set, and after testing the Widow with the wheels on (the main wheels are a much larger dia. then the front wheel, which should have shifted more weight forward), the Widow still is a tail sitter, but by just a tad. I'm wondering if all the added sheet plastic, and bits and parts I added, effected the total weight and distribution enough to cause it? In any event I'll be adding a very small clear piece of sprue to the rear access hatch door to correct this problem.
