Damian, Thanks for your input. Can you share with us a picture or two of the Red Black paint with the straight Black panel lines.
Working slowly but surely on wiring up the 1st engine. With double cylinders it takes just that much longer.
GWH 1/48 scale P-61A Black Widow
Posted: Friday, January 24, 2014 - 10:43 AM UTC
Posted: Friday, January 24, 2014 - 01:04 PM UTC
Terri, Many years ago, OK, nearly 40 years ago, I tried pastels but never could get the hang of them. Went on fine, but no matter how light a 1st few seal coats I put on, I managed to wash most of it right off.
When you apply your pastels, do you do it dry to just the painted surface, or do you coat the surface 1st?
Would adding a flesh color just give me a slightly different shade of black? Interesting idea, just not sure if the color difference would be enough.
Hi Joel , pastels can be tricky but those cheap dollar sotes are crap . I use Grumbacher . Been using the same stickys I bought 30 years ago .
For pastels to work the surfaces needs to have a flat finish for the pastel too stick to . With out this they will not adhere to a gloss surface and will wash away once a finish coat is applied . I'll go over this more on the 190 .
Yes , flesh will greatly aid in the gloss black . I will be using this mix for my build which I do have some progress on . Cockpit is ready for paint which should be getting sprayed this weekend with photo's posted up .....
Terri
Posted: Friday, January 24, 2014 - 01:27 PM UTC
Quoted TextTerri, Many years ago, OK, nearly 40 years ago, I tried pastels but never could get the hang of them. Went on fine, but no matter how light a 1st few seal coats I put on, I managed to wash most of it right off.
Terri
Terri, going to get a basic set of earth tones at a local art shop, and give them a try.
Looking forward to your next update on the FW190.
Posted: Friday, January 24, 2014 - 05:02 PM UTC
Joel, FWIW, i picked up a set of 36 pastel sticks at Michaels. I'm guessing they were Christmas leftovers, but at $4.99 for the set I can't have gone to far wrong...
Posted: Saturday, January 25, 2014 - 08:51 AM UTC
Mark, Thanks for the heads up. I live only a few miles from a Michaels. Off on Sunday, and will be taking a quick trip to see if they still have any.
Posted: Saturday, January 25, 2014 - 11:23 PM UTC
Damian, Thanks for your input. Can you share with us a picture or two of the Red Black paint with the straight Black panel lines?
I will see if I can drag up a couple of photos Joel. I think the last one I did was a monogram P-61 in the Pin-Ups Campaign, but I will be using the same paints on a P-70 which is currently a hangar queen from the recent Nightfighters Campaign. I will make sure I get a few pics as I go.
Posted: Sunday, January 26, 2014 - 01:32 AM UTC
Quoted TextDamian, Thanks for your input. Can you share with us a picture or two of the Red Black paint with the straight Black panel lines?
I will see if I can drag up a couple of photos Joel. I think the las one I did was a monogram P-61 in the Pin-Ups Campaign, but I will be using the same paints on a P-70 which is currently a hangar queen from the recent Nightfighters Campaign. I will make sure I get a few pics as I go.
Damian,
Thanks. I'm really curious to see just how that paint combination looks. I've seen several black aircraft weathered with lighter gray panel lines, so I just joined the crowd as I liked the overall effect.
Posted: Sunday, January 26, 2014 - 05:45 AM UTC
Finally finished the detailing of one engine and cowling assembly. I cut open one of the cowlings engine panels, then added from .040 strip plastic the framing after drilling out the mounting holes. Next I backed up the open cowl flaps with sheet as in real life that's the way they are. After painting all of the various pieces, and then assembling the basic engine, I added the black metal tube which I think houses various electrical wiring for both banks of cylinders. I then cut masking tape to simulate the mounting brackets for the tube and painted it Aluminum. Enamel coated electrical wrap wire was used to simulate the ignition wires on both cylinder banks, then painted hull red. Several enamel washes were then added. The final step was adding the exhaust manifold after the engine was mounted to the cowl assembly.
I've got to congratulate GWH for the most detailed engine I've seen to date in 1/48 scale. Simply outstanding to say the least.
The other engine will be housed in a fully closed cowl, and once the prop/spinner is added, you'll see very little of the front of the engine, so I'm going to take some short cuts with the detailing.
Here's some pictures of the finished engine and cowl assembly.
Posted: Sunday, January 26, 2014 - 08:55 AM UTC
That looks great Joel, very nice work.
Posted: Sunday, January 26, 2014 - 09:08 AM UTC
Damian, Thanks so much for those kind words. I must admit that I really pushed myself to improve the engine details with techniques I've never used before. That black tubing is thick copper wire which was a real bear to bend and get to stay in place. I've never used tape before to make brackets, yet it worked perfectly. Who knew ;-)
Posted: Sunday, January 26, 2014 - 09:12 AM UTC
I agree, there are just sooooooooo many neat little solutions to detailing. When I am struggling to find a solution I usually trawl through any of the ChukW build threads. Pure genius.
I find that various thicknesses of solder are generally more pliable for wiring and tubing needs.
Peterpools
KitMaker: 197 posts
AeroScale: 193 posts
Posted: Sunday, January 26, 2014 - 09:30 AM UTC
JA
Outstanding work on the Big P&W and cowl assembly. Detailing and finish is dead on the money'
Awesome work
Bro
Awesome work
Bro
Posted: Sunday, January 26, 2014 - 09:35 AM UTC
Damian, I really need to buy some various dia solder as I have like just 2 sizes of copper wire. And yes, Chuck's detailing is simply amazing. He has some great techniques that I'm going to try.
Posted: Sunday, January 26, 2014 - 09:36 AM UTC
JA
Awesome work
Bro
Pete,
Thanks for checking out my work. It's getting there, but still not quite up to your level.
Posted: Sunday, January 26, 2014 - 06:52 PM UTC
Hi Joel, really nice work on that power egg
Posted: Monday, January 27, 2014 - 02:33 AM UTC
Hi Joel, really nice work on that power egg![]()
Mal, Thanks for stopping by and having a look. Yeah, that egg came out rather good. Working on the other egg now. Fortunately for me, since it's completely enclosed, other then taking a few short cuts with the ignition wiring, it's staying basically stock.
Posted: Thursday, January 30, 2014 - 03:41 AM UTC
Well, every build has a start date & a completion date, and the P-61A-5 has finally reached it's finish date. The Widow is done, & in it's display case. It's been quite a journey as I pushed my scratch building skills a few notches, & over came a host of issues, to end up with what I consider my best effort to date. I'm certainly more then pleased with the final results. The only issue remaining is that with the props and open glass access panels, I'm more then a little hesitant to turn the Widow over, so I haven't photographed the finished wheel wells or undersides.
Here's a baker's dozen of the Finished Widow. Hope you all enjoy them, as well as my efforts throughout this build.
BTW, it's time for a change of pace from one WW11 prop to the next WW11 prop build. Up on my workbench is a Jet!! Yep, taking my 1st shot at a propless wonder. Taking a shot at the new Academy 1/48 scale F4B Phantom 11 with a few goodies.
Mcleod
KitMaker: 1,028 posts
AeroScale: 939 posts
Posted: Thursday, January 30, 2014 - 04:02 AM UTC
Beautiful, Joel. I'm sure there are museums frothing to have your work displayed.
Posted: Thursday, January 30, 2014 - 04:31 AM UTC
Ben, thanks so much for stopping by, and posting those more then kind words. Don't think any museums, even kiddy ones, will be banging on my door to display my work.
Posted: Thursday, January 30, 2014 - 05:37 AM UTC
WOW, now I have to go back ant examine this post very carefully before I continue on my P-61.
Posted: Thursday, January 30, 2014 - 05:45 AM UTC
WOW, now I have to go back ant examine this post very carefully before I continue on my P-61.![]()
Why thank you Mark. hopefully one or two things I did can help you with your build.
Peterpools
KitMaker: 197 posts
Posted: Thursday, January 30, 2014 - 06:20 AM UTC
JA
Absolutely a brilliant build and no question, your best effort to date and that's going back 30 years! Fit and finish is spot on and the light weathering is absolutely perfect.
Awesome build
Bro
Awesome build
Bro
Posted: Thursday, January 30, 2014 - 07:11 AM UTC
JA
Awesome build
Bro
Bro,
Coming from you and your high standards, I feel like I've really upped my game.
Posted: Thursday, January 30, 2014 - 11:12 AM UTC
Stunning build Joel, one to be proud of!
Thanks for sharing so much detail during your build, threads like this one always give me so much inspiration as well as new ideas and techniques.
Now don't go and get too tangled up in the pointy-nosed wingy thingy world, it's evil. Make sure you return to the land of banging and clattering oily old radials and inlines real soon mate.
Posted: Thursday, January 30, 2014 - 01:15 PM UTC
Well done Joel ! You did one fine job on this build and handle the few issues with easy .
Terri
Terri
