Been really frustrated with the entire painting process on this build. It has nothing to do with the model, it has to do with the paints.
I always use Tamiya Acrylics, and have very slowly been sneaking in more and more Model Master enamels, as nothing paints like enamels, but the long drying time is still an issue for me. Anyway, as I posted, I didn't want to mix all the colors for the RAF Desert camo scheme, so I decided to try both Vallejo model air for the Azure Blue, and the new Italeri acrylics for the Middle Stone & Dark Earth.
I washed the entire model down with Iso Alcohol, and primed as needed with Tamiya Gray primer. I then airbrushed on the Vallejo Azure Blue thinned about 1:1 with water and a few drops of their retarder. I attempted to apply the paint starting at 20 psi but the needle and cone just kept on clogging. Finally got the paint down, but had to use 25 psi, which is absolutely unacceptable, as it causes a ton of over spray.
I let it dry for a few days, then using Tamiya tape I masked off the bottom, (the tape was 1st applied to my arm to reduce the stickiness).
In the interim I did a few practice sessions with the Italeri paints. I thinned it 1:1 with Tamiya X20-A which created "glue" in the glue. Once that mess was cleaned up, I went back to using room temp tap water. I used a mixture of 3 parts water to 2 parts paint plus a drop of retarder. I tested this mixture at 16 psi, and I could draw a fine line with it. No real over spray!! So I used this mixture to paint the base Middle stone color on the entire top surface, and let it dry for several hours.
Every time I touched the paint, it seemed to just scratch right off. Touch my finger nail to it, and the paint just comes right off. Tamiya acrylics once dry just stick to the surface. I did a few google searchers, and sure enough, it's another known issue. The upside is that the paint is self leveling and you can just over paint till the scratches are covered without any tell tail signs. Still a P.I.T.A.
I let the re-touch paint dry another full day. Still the paint easily is scratched off.
I'm doing the camo scheme as a soft edge, so I don't have to mask, but it's impossible with handling not to scratch the surface. thought about applying a few coats of Pledge to help seal the paint, but I'm not sure I want to add that step.
