The IP was given a coat of 50/50 Matt/Goss Lacquer based clear (but doesn't look like it with the reflection from the lights), then the individual instruments got a few drops of Pledge to simulate the glass lenses. Dry brushing with light gray to help pick out some of the details. Then I added a black oily wash, and a dark brown wash to the rest of the cockpit. I tried to keep all of the weathering on the light side as the cockpit is small and really confined. It's real easy to over weather it ,and then it just looks way too dark for it's given space.
Then I glued the other side of the cockpit tub on, and then glued it to one fuselage half. Let the Xtra thin do its thing for 5 min, then glued up the other Fuselage half.
I had previously glued up the misc. fuselage parts, and drilled out the called for holes for the version I'm modeling. The front of the wing flaring is slightly different for a few of the versions, so it's a separate piece. I was somewhat concerned that the parts wouldn't line up perfectly. Boy was I wrong.
Here's a picture with the before and after. The fit is 100% perfect.
Thanks for stopping by. Any and all comments and suggestions as always are more then welcome.
