Hi all,
it's been a while, so there is plenty of progress on the "Salem Representative". This might be a bit of a biggie...
The cockpit, radio equipment, engine and firewall fitted to one of the fuselage halves
Fuselage halves fitted together, you can see some of the filling and sanding work along the top
Another of the small upgrades I have made to this kit - gun barrels. These are just small pieced of brass tubing cut to length, sanded smooth at the ends, and set into the wing openings using milliput. They look a whole lot better than a couple of rough holes, thats for sure
The final small upgrade I have made. I decided that the kit gun sight was utterly hopeless, way too small, and moulded from opaque grey plastic as a part of the instrument panel. This is a small piece of flash from the clear sprue which I have cut and sanded to size and shape, then glued to pedestal from the kit gun sight.
The kit canopy is a bit of a disaster, poor fit, and the lensing effect is terrible, but since I have no alternative, it will have to do. Careful filling is needed methinks...
Base coat of Humbrol metal cote aluminium, the prop, undercarriage, canopy and exhaust stacks are all coated in maskol, so don't worry, they are fine
Remainder of the painting is done, I decided to paint on the black bars instead of using the decals because I though it would give a better finish, therefore, if they are not straight, its all my fault
That is all so far, should be finished by tomorrow maybe, but if not then certainly soon
Cheers, Simon
